Head swap?
Head swap?
No, I'm not changing my own head. I have a 78 Bronco that I put a '71 engine into. It appears that the bearings are bad (loses oil pressure as it gets warm) and maybe other stuff. Should I swap the heads from the '71 onto the engine I pulled that has good oil pressure, but some valve problems? If I do that, what do I need to be careful about. Do I use the push rods that are with the heads? I'm looking to get by cheap if possible.
You can use heavier oil in warm weather, or run an oil line from the front to the rear of the motor. My rule of thumb is that if the lifters on the drivers side don't tap at idle when the motor is warm, then the oil pressure is sufficient, sine the drivers side valve train is the last to get oil.
Otherwise you should be able to swap the '71 heads onto another motor with no problems. All parts will be interchangeable. I would use the pushrods from the motor without valve problems.
Thanks danlee for the information. I'll check the motor again as I just changed the oil and filter, but haven't run it long enough to get it warmed up. The oil pressure was dropping off to nothing and the engine was getting noisy, so that is why I'm considering the swap. I should probably drop the pan and take a look at the main bearings and crank to see what they look like before I do a swap.
bliss1
10-31-2023 11:48 AM
Nobodyhearsyou
15
11-23-2016 05:47 PM
ceeya68
10-16-2010 10:17 PM
rsargent
26
07-16-2010 06:42 PM
