70-72 disc brake conversion
Big,
Although I've read the article that Ken refers to I read after I made the conversion. Find a '73-'79 F100/150, and take the entire front end off of it. It's a bolt in swap. I did mine in one day. Make sure you get both I beams with all the braking system, the master cylinder to use as a core for a rebuilt, and probably most importantly the brake proportioning valve which is located directly under the m/c inside the left frame rail. When you take it off be sure you mark which line goes where. It's a fairly simple matter to swap front ends. You're going to have to replace the proportioning valve as the characteristics between drum and disk are different. It will work but it's going to have to be changed.
Jack your truck up under the frame.
Get another jack and jack up the axle.
Remove the shocks.
Remove the large nut inside the spring.
Remove the clip that holds the top of the spring in place.
Lower the axle to relieve spring tension.
Remove the spring.
Remove the spring seat (large washer) under the spring.
Remove the second large nut that was under the spring seat.*
Disconnect the brake lines. The disk brake lines are of a different design than the drum brake lines.
Remove your tie rod ends.
Tap out the bolt that holds the axle to the radius arm.
Remove the bolt that holds the axle to the frame.
It should be in your lap about now.
To take a phrase from Chilton's - Re install in reverse order.
* This would be a good time to replace the radius arm bushings. Take the big nuts off of the radius arms before you disconnect the radius arm from the axle.
It really is fairly simple. I put '73 F250 axles under my '72 F100. The only other thing I had to use was the tie rod ends on the F250 axle are larger in diameter that on the F100 axle so I had to use the F250 tie rod. I also used the entire braking system off the 250. m/c, power brake booster, proportioning valve. It was all a bolt in swap as the holes were already there. I did move the 73 proportioning valve onto the left inner fender under the m/c cause I didn't want to fight with it under the truck. When you see where the existing proportioning valve is and how much room is under there you'll see why I moved it.
Trail Rider
Remove the shocks.
Remove the spring.
Trail Rider
Similar Questions
I know it's already been asked before but I wanted to ask you directly since your post deals closest to my question. I have a 65 f100 and i'm trying to convert drum to Disc(front). My donor truck was a 73 F100. I only took from that truck the spindles and braking components. I know you said to get the complete front end set up. My question would be is it still a direct fit with me only using the spindles and braking components from the 73? Do I use the 73 Kingpins and bushings set or use the 65's. I'm new at this but I've read many post and feel I can do this with a little help. I'm in the process of buying new calipers etc but wanted to know if at all the differences in both trucks. Thanks in advance.
i did a little more digging. from what i found it looks like kingpin dia. changed in 75. so if you have a 73 it should be the same as your 65. kingpin should be from the disc setup as i believe its longer(but dont quote me on that)
Nicktitan
35
01-28-2017 12:26 PM
denny7170
10-19-2016 01:05 PM
highway90
02-04-2006 11:00 AM
