Ford 2002 F-150 Coil codes
Welcome to the forum
Is the miss the same as before the tune up?
Your local dealer will have the scan tool needed to do a cylinder power balance test on the road to see which cylinder(s) is misfiring. Most other shops don't have the capability to do that.
Otherwise unless a misfire code happens you're pretty much shooting in the dark.
