antifreeze recycling machines
"Most repair shops are now using antifreeze recycling machines. These machines are easy to use tools designed to flush the cooling system, clean your old coolant, and fill the vehicle with rejuvenated coolant. This method also reduces the amount of waste antifreeze that must be disposed of. During a cooling system flush, the old coolant is removed from the vehicle into the recycling machine, and then water is forced throughout the system and drained. Next, the old coolant in the machine is filtered and a technician tests it for its strength (freezing point) and its PH balance. Some new antifreeze can be added if necessary to increase the coolant's strength. An additive is added to balance the PH level of the coolant so it is no longer corrosive, and finally a chemical package containing extra corrosion protecting materials and water pump lubricant is added. Now the recycled coolant is pumped back into your cooling system." internet site
Have you guys every had this done? How did it work?
Stewart_H
508
09-15-2023 04:57 PM
99ExpyProblems
09-01-2018 07:45 AM
