Old 11-12-2014, 12:23 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Guides
Print Wikipost
Serpentine belt replacement
Old 06-17-2006, 03:40 PM
cjspack's Avatar
cjspack
cjspack is offline
Can someone give me the baics (and "tricky" aspects, as well) for replacing the serpentine belt on my 2000 psd? While I'm at it I'm also going to replace the cam sensor, and the stock thermostat and housing with a 203 degree unit from Dieselsite. Thanks.
Old 06-17-2006, 07:27 PM
hink10's Avatar
hink10
hink10 is offline
Just use a breaker bar on the tensioner, relieve tension on the belt and remove. If your radiator hose runs though the belt you will have to remove that. If so, it would be a good time to get a hose that runs behind the belt, only costs $12 or so. Very easy job. Good luck! Steve
Old 06-18-2006, 04:32 AM
cjspack's Avatar
cjspack
cjspack is offline
Thanks hink10. I've read where some say the belt replacement is a pain and a special tool is needed on the tensioner, and others say it's a breeze. I did plan on replacing the run-through hose as well.
Old 06-18-2006, 09:56 AM
hink10's Avatar
hink10
hink10 is offline
Take a look at the tensioner, there should be a square hole. The end of a 1/2 ratchet or breaker bar fits right in.
Old 10-19-2007, 12:26 PM
ZBeeble's Avatar
ZBeeble
ZBeeble is offline
"Take a look" at the tensioner? I'm having trouble seeing anything down there. There is this huge cowling in the way. Do I need to move that? Or which item is the tensioner?
Old 10-19-2007, 06:24 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Look for this:
Stewart
Old 10-19-2007, 06:25 PM
Stewart_H's Avatar
Stewart_H
Whomever told you it was a pain and took a special tool had no idea what they were talking about.
A 1/2" ratchet and you're good to go.
It IS a breeze.
Stewart
Old 10-19-2007, 06:32 PM
Greywolf's Avatar
Greywolf
Greywolf is offline
Look around and see if you can spot the belt routing diagram under the hood too. It beats having to figure it out if you forget exactly how it ran.
Old 10-19-2007, 06:54 PM
Stewart_H's Avatar
Stewart_H
Accessory Drive— 7.3L Diesel Engine Single Generator
<TABLE cellSpacing=0 cellPadding=3 width="70%" border=1><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1 </TD><TD>19D629 </TD><TD>A/C Compressor</TD></TR><TR vAlign=top><TD>2 </TD><TD>19A216 </TD><TD>Idler Pulley (Without A/C)</TD></TR><TR vAlign=top><TD>3 </TD><TD>19A216 </TD><TD>Belt Idler Pulley</TD></TR><TR vAlign=top><TD>4 </TD><TD>10300 </TD><TD>Generator</TD></TR><TR vAlign=top><TD>5 </TD><TD>3D673 </TD><TD>Power Steering Pump Pulley</TD></TR><TR vAlign=top><TD>6 </TD><TD>8A528 </TD><TD>Water Pump Pulley</TD></TR><TR vAlign=top><TD>7 </TD><TD>6312 </TD><TD>Crankshaft Pulley</TD></TR><TR vAlign=top><TD>8 </TD><TD>6B209 </TD><TD>Drive Belt Tensioner</TD></TR></TBODY></TABLE>
Accessory Drive —7.3L Diesel Engine Dual Generator
<TABLE cellSpacing=0 cellPadding=3 width="70%" border=1><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1 </TD><TD>19D629 </TD><TD>A/C Compressor</TD></TR><TR vAlign=top><TD>2 </TD><TD>19A216 </TD><TD>Belt Idler Pulley</TD></TR><TR vAlign=top><TD>3 </TD><TD>10300 </TD><TD>Generator</TD></TR><TR vAlign=top><TD>4 </TD><TD>3D673 </TD><TD>Power Steering Pump Pulley</TD></TR><TR vAlign=top><TD>5 </TD><TD>8A528 </TD><TD>Water Pump Pulley</TD></TR><TR vAlign=top><TD>6 </TD><TD>6312 </TD><TD>Crankshaft Pulley</TD></TR><TR vAlign=top><TD>7 </TD><TD>6B209 </TD><TD>Drive Belt Tensioner</TD></TR></TBODY></TABLE>
Accessory Drive — 6.0L Diesel Engine Single Generator
<TABLE cellSpacing=0 cellPadding=3 width="70%" border=1><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1 </TD><TD>19D784 </TD><TD>A/C clutch pulley</TD></TR><TR vAlign=top><TD>2 </TD><TD>19A216 </TD><TD>Idler pulley (without A/C)</TD></TR><TR vAlign=top><TD>3 </TD><TD>19A216 </TD><TD>Belt idler pulley</TD></TR><TR vAlign=top><TD>4 </TD><TD>10344 </TD><TD>Generator pulley</TD></TR><TR vAlign=top><TD>5 </TD><TD>3A733 </TD><TD>Power steering pump pulley</TD></TR><TR vAlign=top><TD>6 </TD><TD>8A528 </TD><TD>Water pump pulley</TD></TR><TR vAlign=top><TD>7 </TD><TD>6312 </TD><TD>Crankshaft pulley</TD></TR><TR vAlign=top><TD>8 </TD><TD>6B209 </TD><TD>Drive belt tensioner</TD></TR></TBODY></TABLE>
Accessory Drive — 6.0L Diesel Engine Dual Generator
<TABLE cellSpacing=0 cellPadding=3 width="70%" border=1><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1 </TD><TD>19D784 </TD><TD>A/C clutch pulley</TD></TR><TR vAlign=top><TD>2 </TD><TD>19A216 </TD><TD>Idler pulley (without A/C)</TD></TR><TR vAlign=top><TD>3 </TD><TD>19A216 </TD><TD>Belt idler pulley</TD></TR><TR vAlign=top><TD>4 </TD><TD>10344 </TD><TD>Generator pulley</TD></TR><TR vAlign=top><TD>5 </TD><TD>3D673 </TD><TD>Power steering pump pulley</TD></TR><TR vAlign=top><TD>6 </TD><TD>8A528 </TD><TD>Water pump pulley</TD></TR><TR vAlign=top><TD>7 </TD><TD>6312 </TD><TD>Crankshaft pulley</TD></TR><TR vAlign=top><TD>8 </TD><TD>6B209 </TD><TD>Drive belt tensioner</TD></TR></TBODY></TABLE>
Accessory Drive — 5.4L, 6.8L without A/C
<TABLE cellSpacing=0 cellPadding=3 width="70%" border=1><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1 </TD><TD>8678 </TD><TD>Belt idler pulley</TD></TR><TR vAlign=top><TD>2 </TD><TD>10344 </TD><TD>Generator pulley</TD></TR><TR vAlign=top><TD>3 </TD><TD>3A733 </TD><TD>Power steering pump pulley</TD></TR><TR vAlign=top><TD>4 </TD><TD>8509 </TD><TD>Water pump pulley</TD></TR><TR vAlign=top><TD>5 </TD><TD>6312 </TD><TD>Crankshaft pulley</TD></TR><TR vAlign=top><TD>6 </TD><TD>6B209 </TD><TD>Drive belt tensioner pulley</TD></TR></TBODY></TABLE>
Accessory Drive — 5.4L, 6.8L with A/C
<TABLE cellSpacing=0 cellPadding=3 width="70%" border=1><TBODY><TR><TH vAlign=bottom>Item</TH><TH vAlign=bottom>Part Number</TH><TH vAlign=bottom>Description</TH><TR vAlign=top><TD>1 </TD><TD>8678 </TD><TD>Belt idler pulley</TD></TR><TR vAlign=top><TD>2 </TD><TD>6312 </TD><TD>Crankshaft pulley</TD></TR><TR vAlign=top><TD>3 </TD><TD>10344 </TD><TD>Generator pulley</TD></TR><TR vAlign=top><TD>4 </TD><TD>3A733 </TD><TD>Power steering pump pulley</TD></TR><TR vAlign=top><TD>5 </TD><TD>8509 </TD><TD>Water pump pulley</TD></TR><TR vAlign=top><TD>6 </TD><TD>6B209 </TD><TD>Drive belt tensioner pulley</TD></TR><TR vAlign=top><TD>7 </TD><TD>19D784 </TD><TD>A/C clutch pulley</TD></TR></TBODY></TABLE>
That should cover the bases.
Stewart
Old 10-19-2007, 09:04 PM
Greywolf's Avatar
Greywolf
Greywolf is offline
Well...
YES, I suppose that works too
"Sire, we should explore a technology - call it overkill - which renders to all of our citizens far more than they require..."
-Civilization 2 game, Economic Advisor
Old 10-19-2007, 09:23 PM
Stewart_H's Avatar
Stewart_H
Well...
Well, here's how my line of thinking went (uh oh... lol)
First, when I was composing my response, I only provided the routing for the 7.3L PSD. Then I figured since ZBeeble has a 6.0L, and he also posted in this thread, I better also include the routing diagram for the 6.0L PSD's.
THEN I figured someone with a 6.8L gasser would post up eventually (today, tomorrow, next month, next year after digging up an old thread, etc) and ask if I could provide the routing for their gasser.
So I used a shotgun to kill a fly. All in one post.
Stewart
Old 10-19-2007, 09:26 PM
Greywolf's Avatar
Greywolf
Greywolf is offline
Good on you - and WELL DONE!
Old 10-19-2007, 11:57 PM
2manykids's Avatar
2manykids
2manykids is offline
Stewart
understand
Old 10-20-2007, 12:25 AM
Stewart_H's Avatar
Stewart_H
Thanks for the rep points!
Stewart
Old 10-20-2007, 02:49 PM
7.3 4X4's Avatar
7.3 4X4
7.3 4X4 is offline
If a parts guy looks at you funny when you ask about an upper radiator hose that doesn't run through the belt, just tell him you need a hose for an engine with dual alternators!
Quick Reply: Serpentine belt replacement
