Big Intake
Big Intake
I know that this topic is like beating a dead horse because there are a ton of posts out there. I am looking for information from anyone that is running the jobe performance intake on there 6.0. That filter looks like it would really bring in the air. And they are claiming a ton of horse power and torque. I need some real time, real life feed back on that filter before I spend the money. Thanks For the info.
Check out post three of this thread. May be worth PMing this guy.
https://www.ford-trucks.com/forums/s...d.php?t=498810
I would be interested in what you find out. I have never heard of this before last night.
Originally Posted by Mark at DPPI
Firemedic61,
If you want a true cold air intake that seals off the hot air and want a filter that stops the dirt check the AFE Stage II Pro Guard 7 system. Best of the best etc. Call us if you have any questions on it!!
Mark @ DPPI
Mark @ DPPI
much appreciated.
Originally Posted by Firemedic61
I did PM him, but have not yet heard back.
I LOVE my Jobe Intake. I think it's exceptional quality and I think it let's tons of air in and seals off the heat very well. Yes it's pricey, but it does come with an Optima Battery. Very nice!!
Originally I had a Green Power filter in the stock box. It worked well until I added the Banks Techni-cooler kit. With the stock intercooler and the Green Filter and 4" turbo back I was getting 27-28 PSI boost. After installing the Banks intercooler, the boost dropped to 20-21 PSI. Listening to it, it sounded like it wasn't getting enough air. You could almost hear the air being sucked into the stock box in places it wasn't supposed to. After much searching on the net, I found Reagan Jobe. I ended up getting the Filter kit, two Optima Yellow tops (wanted deep cycle and both the same) and the crossover Valve cover vent tube. Install took a little while due to the Banks Intercooler not allowing it to fit quite as designed, but wasn't too bad. After the install, I was back to getting 27-30 PSI of boost. I could honestly feel the power.
Hope that helps you out.
In case you're curious - I'm running a 5.12 second 0-60 & a 14.6 in the 1/4 mile. That's all before the Torque Converter and NOS though. Hopefully, Friday I'll see what she'll do with those two additions.
admorris,
I understand, here's some info for you:
The PG7 filters within 1/2 of 1% as well as a paper filter, nearly nothing etc.
THE 75-10392 system produces 18 HP and 100 lbs of torque at 850 RPM over stock.
Flow rate over stock is increased from 215 CFM to 278 CFM.
Cold air only intake, unlike most that have an unshielded filter under the hood.
Easy access for filter service.
Has a supplemental air intake function if you want to cut it open for even more CFM of flow.
Probably some stuff I forgot too.
Mark @ DPPI
Mark @ DPPI
admorris,
Mark @ DPPI
Mark @ DPPI
Originally Posted by BassCat
I would ask you though what CFM does the filter / intake combination flow at stock 6.0 rated power which is 3300 rpm?
For that, I'd point you to the man that makes it:
http://www.JobePerformance.com
I'm strictly an end user with no way to test that.
Letting tons of more air in with this set-up sounds highly exaggerated without a rated power test to compare with the stock set-up.
It's like looking at the stock exhaust and a 5" exhaust laid side-by-side.
BassCat,
Your info is great, but AFE tested the HP gains on their in house dyno. The CFM ratings is not listed at any particular RPM in their information, the HP rating was at 850, basically off idle they go those extra HP numbers. I agree that you have to test at the same RPM, whcih they do, I just don't have that RPM available etc.
You can also get SOTP results by feeling and seeing a faster spool up on the turbo as well as lower EGT's at the same RPM's when comparing to the stock system.
Mark @ DPPI
Mark @ DPPI
BassCat,
Mark @ DPPI
Mark @ DPPI
Take care
1977mud400
05-21-2014 10:03 AM
10bands
06-17-2007 02:49 PM
