emergency brake
I had the same problem until I forgot to turn it off and drove about 15 miles before I realized it. Anyway, I think the problem is if you don't use it much the drum portion builds up with rust and then doesn't make much friction to hold. Mine works much better now that I burned half the pads off. Not suggesting to do it, but rust is the probable cause of it not holding. I could be way off and sure someone will correct if I am wrong, but that is what I am thinking is going on and why mine now works much better.
Originally Posted by macksarf
the emergency brake dont brake enough. Is there anything i can do, else then change the pads? Any adjustement or sometin?
Thanks
Fred.
Thanks
Fred.
HILLBILLY BOB
08-21-2015 02:37 PM
