Under Bed Gas Tank
I plan to do the same on my 56. One of the guys here (I forget who) did a very slick install of a Chevy Van tank that fits behind the rear end and between the existing frame crossmembers without needing to modify the frame. (I hope he sees this thread and attaches the photo of his install). The tank is secured by straps just like the OEM setup. You'll need to graft a Ford sender to it unless you are changing the gage.
The link below is for a new Chevy Van tank.
http://www.gastanks.com/prodinfo.asp?number=GM-8A
Randy Jack,
I think I am the guy you are referring to. Look in my 2nd photo gallery for more photos. You can email at this username at comcast.net for more photos and info. Here's a photo of my tank, 77-82 Chevy/GMC van 22 gallon. No cutting or notching required. Drill holes to bolt the straps to and go.
Hope this helps.
Donald
Hope this helps.
Donald
tacson -
Yep. That's the photo I was referring to. Great install.
I don't get that good of mileage, so I'm thinking about the 31 gallon tank. It is longer, so I'd need to move the crossmember back about 6 inches, but your setup is definately the path of less resistance.
Did you use a Ford sender or a Chevy gage?
I have aftermarket gauges in my truck. So i took the sending unit that came with the gauges and mounted it to the bottom side (inside the tank) of the GM unit and adjusted the arm on it to read my fuel level. It is not dead on but I have a solution to that coming this winter. For a guy or gal looking for functionally and ease of install and easy on the wallet. It is not to bad of a deal.
Originally Posted by tacson
Randy Jack,
Hope this helps.
Donald
Hope this helps.
Donald
How far down does it hang (the fuel tank)
on
Why Re-invent the Wheel.
Find a '56 Panel Truck & use the Frame Mounted Tank from IT, remember to take All the Support Brackets & Bolts for it when you dismount it.
Just be sure to cut out the Indent in the side of the body where the Fuel Filler Spout goes so you only have some minor body work to do on yours.
Bobby,
I suspect the tanks that Tacson and myself both used are probably the same tank, though the catalog application listing is different. They both have a 31 gal version and the only difference in dimensions versus the 18 gallon versions are the depth. From memory, the 31 gal. versions are about 5 or 6 inches deeper......
I loaded a gallery of my tank install as well.........filler on the passenger side....
Regards,
Regards,
I ended up routing the exhaust outside the tank on each side by about 2 inches. I have one of the Hagan door that is going to be mounted in the fender once I swap out the spare tire fender. I fill the tank by the filler neck that runs up underneath the fender behind the tire. My plan was for that to be temporary but 12K miles later I guess I am having to much fun driving to change it. Been on the road since August of 2003. Hope this helps
Donald
Ferguson you are right the tanks are the same depth is the difference.
Donald
The tank I used was for a mid 80's Blazer. It appears that the dimensions are the same. The only difference I see is where the fuel filler goes intot he tank. On the Blazer tank (and I'm guessing Suburbans are similar) the fule neck come out of the top of the tank to the right of the fuel sending unit (passenger side top). I set my tank up between the frame rails for some more clearance (I have the 31 gallon tank). I used the stock Blazer mounting straps and sending unit (I have GM gauges) and had to build a couple of x-members to hold everything
I routed the fuel filler hose between the frame rail and the bed and used a marine style flush mount fuel filler neck that i set into the passenger side rear fender
Here's a shot before I painted the frame;
I wish I would have read this sooner then I probably could have went to the salvage yard for a tank. I ordered the 70 Mustang tank 22 gal. today that I will probably install next month tshipping cost fifteen dollars less that the tank/sending unit itself. Anyone who has used this conversion what gas gauge are you using. Anyone in the market for a stock type polly tank?
Jaye
Jaye
