03 Expy Musty Odor w/ AC
Where is the filter
I have a little musty smell too....it goes away after a while, but I wonmder if the filter system for incoming air for the HVAC system is easily accessable for clearing. ANd does anybody recommend any kind of chemical tratment? Or should I consider baking soda like I have in home refigerator?
AC Smell,
If you see water under the truck the when the AC is running the drain is fine. The drain does not normally get clogged. The musty smell is a fungas that grows on the evaporator which is the item the air passes through before entering the cabin. There are no filters etc... The early Expy's had a filter kit avail but few sold. Ok how to fix this, first when you are parking your truck run the system on vent for a minute or two to dry out the evaporator, if you live in a very humid climate you might need to get a commerical product to kill the mold/fungas. Most of the time lysol will work, I don't suggest the bleech idea due to the fumes and the effects on ABS plastic over time. Run the system on low and spray lysol at the base of the windshield on the passenger side into the plastic screen looking mesh. I would do this with all the windows down. Good luck let us know what happens.
Dave
Dave
I took my '03 in to the dealership with the same complaint, musty smell. They sprayed some kind of chemical through the system to kill the fungus/bacteria. By doing this they ended up melting all the vents in my dash and staining the seats and door panels. They had to replace the dash vents and clean the interior of my truck. Be careful what you are spraying into the ventilation system, and always park the truck with the selector set to vent to allow the vents to "air out".
Originally Posted by pronstar
Using settings other than MAX A/C may also help if you use this setting all the time.
MAX A/C recirculates interior air, and doesn't introduce outside air to the system.
But the other posters have the likely solution.
thebeastof1980
1997-2006 Expedition & Navigator
08-17-2007 08:07 AM
