Throttle Body
IMHO you will not get a power gain on a factory-stock engine.
But if I'm mistaken, and there are minimal gains to be made, then they would only be at the top of the RPM scale at WOT.
Even guys with blowers tend to keep the stock t-body, if that means anything.
Your mpg will be the same until you start flowing more air, wich will again be at the top of the RPM range. At anything other than WOT, there will be no effect to either MPG or power...because the throttle will be limiting airflow, so you won't be taking advantage of the larger t-body's greater flow. Assuming your engine can ingest the extra flow, which I don't think it can.
Just my two cents
Just my two cents
phoneman91
03-04-2007 03:03 PM
74F250
01-09-2003 08:35 AM
