Throttle bodies
Old Dec 10, 2002 | 11:31 PM
steve83's Avatar
steve83
Throttle bodies
Old Dec 23, 2002 | 06:53 PM
MW95F250's Avatar
MW95F250
Throttle bodies
Does an aftermarket "hi performance" throttle body actually make a difference in power and gas mileage?
Old Dec 23, 2002 | 10:34 PM
heathdaily's Avatar
heathdaily
Throttle bodies
The only way I see it helping you is if your current throttle body is a restriction. Unless you've taught the engine to breathe deeper, like cam, headers, and port work, it's not likely to do anything except lighten your wallet. You'd probably be better off spending the $$$$ on better exhaust and/or high-flow cat, if you decide to keep a cat on it. I believe SilverStreak tested his 4.9 throttle body by using a vacuum gauge at full throttle, mounted right behind the throttle body. If it reads 0 there's no restriction.
