4.0L Performance
Old 04-20-2006, 08:01 PM
Bimmerboy1989's Avatar
Bimmerboy1989
Bimmerboy1989 is offline
4.0L Performance
Ok, I have a 1990 4.0L V6 Ranger that needs new heads. I was wondering what kind of things I could do to the engine while I have the heads off. Any input would be greatly appreciated.
Old 04-23-2006, 07:31 AM
RomerB2's Avatar
RomerB2
RomerB2 is offline
New cam? What about porting the heads?
Old 04-23-2006, 10:23 PM
Rockledge's Avatar
Rockledge
Rockledge is offline
Delta Cams offers a Rocker Arm Assembly/Pushrod Kit for the 4.0L OHV. Part # F-40 KIT. It doesn't do much for performance but the kit is highly recommended as part of a rebuild.
http://www.deltacam.com/index.php
Old 05-21-2006, 08:16 PM
wendell borror's Avatar
wendell borror
wendell borror is offline
Comp Cams Sells A Good Midrang Cam For It, Also Port,and Polish The Heads, Add Larger Injectors, Bigger Tb, And Maf, A Set Of Headers, And You'll Be Rocken!
Old 05-21-2006, 10:48 PM
RangerPilot's Avatar
RangerPilot
RangerPilot is offline
Indeed, great advice.
Intake and exhaust as well.
RP
Zach
Old 05-22-2006, 01:01 AM
d3adp00l's Avatar
d3adp00l
d3adp00l is offline
I am looking into better ratio rockers, but as far as I can tell these 4.0s ohv have a few things working against them valve sizes, rocker ratios, and compression ratio. Have the machine shop check your clearances(as I have yet to have mine that far apart yet) to see how of the head could be milled to get it around 9.5/10 to 1 compression. Increasing flow and increasing compression means power. The sohc 4.0 is running 9.7 comp and 1.8/1.5 valves which is pobably the largest factors for its 207 hp rating.
Old 05-22-2006, 01:03 AM
d3adp00l's Avatar
d3adp00l
d3adp00l is offline
Btw I forgot I believe these motors are all using dished pistons, might be able to use flats and get the ratio to the right spot.
Old 06-16-2006, 12:56 PM
jv982's Avatar
jv982
jv982 is offline
What intakes are available for the '90 4.0 ranger? I have just installed an e-fan on my truck and have ran into clearance problems that will not be solved with the stock intake.
Old 06-16-2006, 05:17 PM
wendell borror
I did some checking for you, and the oldest I could find was k&n, they have an intake for a 96 4.0, they had a piture, and it looks pretty basic, may have to do a little fabbing, that or get one of those generic kits from ebay. It's hard to find performance stuff for the older rangers. The good news is, Morana v6 racing has developed a 4.5 stroker kit for the ohv 4.0, that should be an awesome product.
Old 06-19-2006, 03:19 AM
d3adp00l's Avatar
d3adp00l
d3adp00l is offline
I just put together a "cold air" intake for my 92 4.0 using 3" intercooler pipe from ebay I used one 90 degree steel elbow and a 45 degree elbow. I just had to trim the pipes down to fit, no clearance problems at all. the fit on the stock throttle body was a little sloppy fixed by a tight clamp, and I am using a v8 maf body with the v6 sensor on it, with the t/b bored out to 70mm using a v8 butterfly. The aircleaner was just a cone type that clamped to the maf.
Old 06-19-2006, 03:22 AM
d3adp00l's Avatar
d3adp00l
d3adp00l is offline
I have compiled a list of modifications for the 4.0 and am soon to finish installing them and have it dyno'ed I will be posting the cost and descriptions of them soon, should equal at least 225hp n/a for a reasonable price.
Old 06-19-2006, 03:42 AM
RomerB2's Avatar
RomerB2
RomerB2 is offline
That sounds pretty cool, 225 hp's out of a 4.0 is pretty good. I've given my swap a good thought, and I've decided to go ahead and go with a 5.0.
Old 06-19-2006, 05:33 AM
wendell borror
Make sure to check your emisions laws, I couldn't legaly put a 302 in my 04 here in ohio.
Old 06-19-2006, 02:21 PM
RomerB2's Avatar
RomerB2
RomerB2 is offline
Ohh I forgot to say, I have a 90 Bronco II.
Old 06-19-2006, 05:09 PM
wendell borror
you should be allright then, the law states here, that the swapped in motor must be of the same year as the vehicle, or newer, they were using the 5.0 up to 01 in the explorer. To be legal, I'd have to swap in the 4.6, thats a big motor as it's a cammer, to much hassle, I'm just gonna build my 4.0 cammer, it has as much hp stock, as the old stock 5.0 mustang, "well", allmost.
Quick Reply: 4.0L Performance
