Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
  #1 (permalink)
Old 04-11-2006, 10:54 PM
*mustang* *mustang* is offline
Garage is empty, add now
*mustang* is starting off with a positive reputation.
99 Superduty Transmission problem
I have a 99 f-250 with a v-10 and an automatic tranmission. I just purchased the truck and on the drive home I was cruising at 65 mph and the transmission came out of gear and the engine kept reving. I kept going for a while but it wouldn't kick back into gear. It wasn't until I completely stopped the truck and started driving again that it would start shifting. It was a 3 hour drive home and this continued for about an hour progressively getting better and better until it stopped doing it completely. The speedo goes nuts right after it happens as well. It is obvious that they pressure washed the engine compartment before I bought it because it was as clean as the day it came off the assembly line while the rest of the truck was still as dirty as could be. I used cruise control for a bit and it was lurching while I had it engaged. At first I assumed that it was a bad torque convertor but the truck runs and shifts perfectly the rest of the time. Has anyone else had similar experience? Any advice would be greatly appreciated!
  #2 (permalink)
Old 04-12-2006, 05:01 AM
FortyFords's Avatar
FortyFords FortyFords is offline
FortyFords is gaining momentum as a positive member of FTE.
Did you notice the abs light coming on?
could be rear speed sensor??????
But something fishy here because Ihave never seen the tranny go into neutral when that happens.
If the washed the engine ,there may be water in the spark plug holes.
It will cause misfires possibly being your lurging,but that also could be your speed sensor.Compressed air blow out around all the plugs.
Take a look at it ,its mounted on top of the rear diff ,clean all the dirt away from area before loooking at it.
Rich
__________________
" All levers like real trucks should be!" "Cool enough for me!"
" BSEG CLUB" 10 Strokin and 4 Smokin!
  #3 (permalink)
Old 04-12-2006, 05:24 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
1999 Ford F-550
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
http://www.facebook.com/http://facebook.com/Kwikkordead#!/Kwikkordead
Welcome to FTE Mustang.
With the speedo going crazy, the first though that comes to my mind as well is the VSS mounted on the rear differential sending a bad signal. Very common problem and a cheap fix at around $25.00 for the part from Ford.
__________________
Dan
1999 F550 4x4 ZF6 pulling a Cedar Creek 36RLTS. Lotta mods.
1999 VW Jetta TDI 5speed stick, Titan 520's, CCV, EGR, CAT.
2000 VW Passat 1.8t Tiptronic. ZZOOOOOMMMM!!!
1996 Audi A4 Quattro. Unstoppable in the snow and ice.
You cannot explain or explain away the power of God.
  #4 (permalink)
Old 04-12-2006, 06:50 AM
But would the speed sensor kick the transmission out of gear? I believe I was in 4th gear at the time. I was cruising along and then it just jumped up to 6000 rpms and would not re-engage. Thanks for the help!
  #5 (permalink)
Old 04-12-2006, 07:24 AM
FortyFords's Avatar
Quote:
Thats what I said!
You could have a problem internal in the tranny.
But as said the rear diff is a easy fix!
Than a $1200 tranny
Rich
__________________
  #6 (permalink)
Old 04-12-2006, 07:18 PM
Thanks Rich, i'll give it a shot!
  #7 (permalink)
Old 04-13-2006, 02:06 AM
MadMedic20's Avatar
MadMedic20 MadMedic20 is offline
MadMedic20 is starting off with a positive reputation.
Post back and lets us know what it was.
__________________
2000 Excursion V10 4x4 4.30s
2000 F250 Super Cab V10 4x4 4.30s (gone).
2004 Mustang GT 5Spd.
  #8 (permalink)
Old 04-17-2006, 08:22 AM
VSS seems to have worked. I have only been able to do a limited amount of driving but I haven't had a problem yet. Thanks again guys!
  #9 (permalink)
Old 04-17-2006, 09:55 PM
1999 Ford F-550
Excellent.
__________________
Dan
Tags
2001, 4x4, 99, duty, f250, fix, ford, forums, problem, slips, super, superduty, trans, transmission, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
