4x4 V8 Triton
Originally Posted by zman764
That would be the glory of 4lo
I have climbed 15 inch high mud walls to get back into some property before. Pulled up to it paralell put it in 4 lo cut the wheels she jumped right up it... Thankfully I have skid plates and 32" tires ha ha.
I had it in 4 Hi. I followed your advice and posted Q's in the 4x4 section...thanks bro!
Originally Posted by Roger_56
Yeah....about. So it is bad to operate your 4x4 on the highway at 60 + mph
The only time I use my 4WD, is when I'm stuck while in 2WD, or if I know I wont be able to make it in 2WD....all of which are off-road only, unless there is snow on the ground.
Originally Posted by ATC Crazy
Why in the world would you need to use the 4 wheel drive on a dry, paved surface anyways....much less at 60mph?!?!
I wouldn't use 4x4 unless you need it. I switch mine on every once in a while to keep things moving, so it'll work when I need it to. If you need 4x4, you shouldn't be going over 100 km/hr in the first place. You CAN, but it's not recommended going much over 40 or 50 mph with 4wd on. Turning is ok with 4x4, just no tight turns like turning into a parking space. Turning on a windy road is fine. But as was said before, to work properly, the tires need to break traction in 4x4, and if they don't, the driveline will be fighting itself, and eventually something in the driveline will break. So switch it on at a low speed on a straight road every once in a while, but only use it for an extended period when 2wd will not handle it.
