01' F-350 7.3l diesel A/C Problems
Quick question for a quick awnser hopefully as the local Ford dealership is awaiting my decision. Ford has my truck in for a/c problem I lost all but 2 ounces of freon out of the system. I did notice a nasty oilly residue on the back of the a/c compressor and the two lines comming off of it. They say that the pop off valve on the back of the compressor is shot and needs replaced and while they are at it they will replace the two o rings for the lines comming off the compressor, then recharge the system. They said it will only take about 2 hours.
They want $585.00 to do this. Is there such a thing as pop off valve and is that price a little high?
Sorry this is so quick and to the point but they are waiting for me to get back to them.
They are only charging you $500 too much.
Do you have any idea what it costs the owner of that dealership to fill up his plane so he can fly around just for the heck of it?
Replace the o-rings and get it evacuated and recharged.
They will use a leak detector to "sniff" their work and the pop=off valve.
If its leaking, its a simple fix.
Recover the R134a, R&R the valve, evac and charge. Maybe another $50 repair.
I went last nite and picked up my truck and asked that a tech (not the one who worked on the truck though) show me this pop off valve and he said he did not know what I was talking about and all he could guess was the high pressure shut off switch but that there is no reason for that to leak. There is a little oily residue again right where the two lines come into the compressor.
I opted to just take the truck without Ford fixing it. I went to parts and bought a new pressure cutoff switch and the two o-rings for only $14.18. I will replace them myself then take the truck in to have the system charged. I think in the end that I will have saved my self about $500.00.
Thanks for the replys.
Binkowski
05-28-2016 12:28 PM
annaleigh
04-01-2016 04:30 PM
hrvat
45
03-17-2016 09:41 PM
bigperm2
02-28-2016 06:53 AM
