went to a yard sale the other day an I bought a ignition tester is made by snap on.
it seems like you hook your ingnition coil up to it to check your coilit makes a sprark jump a gap you adjust the gap and see how much gap you get before it stops,anyone know of this tool not sure how to use it?
Hey soso that tool is part #SGT1 used for checking no start conditions. It measures kv in dis, electronic and standard igntion.
Sells for about $20.00.Can also ck coil out put.I am the local snapon tool dealer.
hope that helps, chuck
