engine swap
engine swap
TRD-4145 at www.summitracing.com what will i need to install this engine. will this mount work? TRD-4145 and what else will i need for it.
this is my first engien swap
what will i need to put in C-6 pr C-4 trans in, how/what do i need to mount it? do i need to mount it?
I used these, yes they work for a 302
I modified mine to put the engine off center to the passenger's side like ford had them, they are designed to hold the engine in the middle of the bay.
You will also need a transmission adapter. If you use a stock ford one it is off center too.
I see you have a '63. you will have to modify the rear engine/transmission mount cross member to clear your application too. Don't cut it right out. It holds the parking brake cable.
Yes, Ford engines are off center in all their old trucks, 1- 3/16" inches (I am going by memory, someone correct if the number is different) to the passenger's side. the shape of the indent in the firewall will not line up on your engine if you put it in the centre..
Transdapt also make the transmission mount. It will work with a C6. It is meant to go with their engine mounts, so it is centered too.
Yes they bolt to the frame rails.
fordsrgrt
04-22-2018 07:50 PM
Bozworth
57
10-03-2013 12:37 AM
rockcrawler_101
06-27-2011 02:55 PM
Red Star
Ford vs The Competition
04-10-2008 07:26 PM
