Ford 352 engine build up
I have a ford 352 that will likely be rebuilt. Is there a web sit that will show what parts and what needs to be done to make this engine tear up the pavement. I will have some of the work done by someone, but will assemble as much as possible myself. Without nitrous, what is the best possible HP I can pull out of this engine.
thanks.
thanks.
2nd'd
I'm planning on building one up myself here soon. I want to build it as a 352 though.. none of that bigger better stuff just max out the 352 for a fun/towing rig. I would like someone to quote a build here (uhhmmm Rusty) heres a challenge keep it $$ low as possible, torque strong, no headers stock manifolds, prefer to keep the 2bbl... Basically want the stock look with the most pulling torque for the buck.. I guess it's just Cam descision and possble home port job ?? May need new pistons, would go for a step up set if the $$ is right.
Anyone.....
Anyone.....
This is the part that cracks me up, everyone on here seems to be worried about a number. I'm not here because I race the thing or have something to prove.. I just have an old truck I'd like to keep simple but improve as best possible with the stock outer look. I want it to look like it did in the day and improve on power and torque without robbing a bank to do it. When it's done it will carry a 8' box camper and tow a 17'6" fiberglass classic Glasspar up the Grapevine into the Central Ca lakes for summer fun. Possibly take off without the boat from time to time up north for some fly fishing. Just an ole' truck kinda truck,
I honestly think that the first place to go for improvement is with headers and a stock 4 barrel intake and carb. If you're willing to port and polish the heads yourself then I'd certainly do that because it will make a huge difference and it's mainly time you're investing to do it. I'm not sure if there would be much benefit to a cam change from stock without at least putting headers and the 4 barrel intake and carb. If you're good at "scrounging" then you can find a stock 4 barrel intake and a used carb pretty cheap....and many headers aren't that expensive either.
oops...back to what started this thread....convert the 352 to a 390 and follow all of Kurt's advice for the 390 build....you'll end up around 400 hp and similar torque #'s without the NOS.
Good Luck!
Tracy
Good Luck!
Tracy
yeah... unless you're going to change the exhaust manifolds out for something with better flow, headers or some cast iron stock headers, anything else you do like head porting and big cam, or 4 bbl intake isn't gonna net you anymore power... i ran an RV cam in a 390 and it was a bit better than stock...
I have a real mild FE cam that's work OK in a stock 352. And they're cheap too.....under eighty bucks. That said I'd still chase 390 stuff down if it were mine. The parts (crank and rods) are free or nearly so, and the power increase is fer real even if you just build it stone stock from there.
<TABLE height=199 cellSpacing=0 cellPadding=0 width=430 border=0><TBODY><TR><TD colSpan=9 height=17>Performance Camshaft; Part Number SH7204<!--$end exclude$--></TD><TD width=102 colSpan=4 height=17></TD></TR><TR><TD width=430 colSpan=14 height=8></TD></TR><TR><TD width=184 colSpan=5 height=13></TD><TD vAlign=top noWrap colSpan=3 height=17 rowSpan=2>lifter-type
</TD><TD width=26 height=13></TD><TD vAlign=top colSpan=4 height=17 rowSpan=2><!--$addOn href=""fontFace=ArialproductId=camsh7204target=pub lish.local=falsefontSize=14addOn=resource\:/resources/addons/store/custom/custom.addonproductField=lifter-typeraw.previewText=addOn.class=com.yahoo.sitebuil der.elements.StoreCustomElementpreviewText=Hydraul icitalic=falsebold=falsefontColor=000000underline= falseobject.class=stringmandatoryField=productIdfo rmat=text$--><!--$begin exclude$-->Hydraulic<!--$end exclude$--></TD><TD width=10 height=13></TD></TR><TR><TD width=1 height=4></TD><TD vAlign=top colSpan=2 height=90 rowSpan=3><!--$addOn addOn=resource\:/resources/addons/store/productPhoto/productPhoto.addonproductField=imageaddOn.class=co m.yahoo.sitebuilder.elements.StoreCustomElementhre f=<\!--\#ystore_catalog id\="camsh7204" field\="image" format\="text"--\>fontFace=ArialpreviewText=/sitebuilder/preview/store/images/yhst-49878277102112_1886_3815129productId=camsh7204targ et=current windowfontSize=14publish.local=falseobject.class=i magemandatoryField=productId$--><!--$begin exclude$--><!--$end exclude$--></TD><TD width=58 colSpan=2 height=4></TD><TD width=26 height=4></TD><TD width=10 height=4></TD></TR><TR><TD width=1 height=16></TD><TD width=304 colSpan=11 height=16></TD></TR><TR><TD width=1 height=70></TD><TD width=60 colSpan=3 height=70></TD><TD vAlign=top colSpan=6 height=102 rowSpan=3><!--$addOn href=""fontFace=ArialproductId=camsh7204target=pub lish.local=falsefontSize=14addOn=resource\:/resources/addons/store/caption/caption.addonproductField=captionraw.previewText=C aptionaddOn.class=com.yahoo.sitebuilder.elements.S toreCustomElementpreviewText=Big Block "FE" 1963-76 352-427 adjustable valvetrain increases lift; intake-duration@.050 lift 204; exhaust-duration@.050 lift 214; intake-lift .484; exhaust-lift .510; lobe sep angle 112italic=falsebold=falsefontColor=000000underline =falseobject.class=stringmandatoryField=productIdf ormat=text$--><!--$begin exclude$-->Big Block "FE" 1963-76 352-427 adjustable valvetrain increases lift; intake-duration@.050 lift 204; exhaust-duration@.050 lift 214; intake-lift .484; exhaust-lift .510; lobe sep angle 112
</TD><TD width=11 colSpan=2 height=70></TD></TR><TR><TD width=186 colSpan=6 height=20></TD><TD width=11 colSpan=2 height=20></TD></TR><TR><TD width=8 colSpan=2 height=12>
</TD><TD vAlign=top colSpan=2 height=29 rowSpan=3><!--$addOn addOn=resource\:/resources/addons/store/order/order.addonformId=Form2addOn.class=com.yahoo.siteb uilder.elements.StoreOrderElementproductId=camsh72 04fontColor=000000publish.local=falsemandatoryFiel d=productIdorderText=Order Now$--><!--$begin exclude$--></TD><TD width=57 colSpan=2 height=12></TD><TD width=11 colSpan=2 height=12></TD></TR><TR><TD width=8 colSpan=2 height=6></TD><TD width=301 colSpan=10 height=6></TD></TR><TR><TD width=8 colSpan=2 height=11></TD><TD width=101 colSpan=3 height=11></TD><TD colSpan=4 height=17 rowSpan=2><!--$addOn href=""fontFace=ArialproductId=camsh7204target=pub lish.local=falsefontSize=14addOn=resource\:/resources/addons/store/productPrice/productPrice.addonproductField=priceaddOn.class=co m.yahoo.sitebuilder.elements.StoreCustomElementita lic=falsebold=falsepreviewText=$79.95fontColor=000 000underline=falseobject.class=stringmandatoryFiel d=productIdformat=html$--><!--$begin exclude$--></TD></TR></TBODY></TABLE>
Barry R.
survivalmotorsports.com
Barry R.
