351m dies after warm up
78 351M dies after the truck warms up. When I drive it, the truck will start up fine, but in a couple of minutes, it warms up and tries to choke down. Or so I thought. I am afraid the vacuum advance is kicking in and it just feels like it is choking down. I get alot of black smoke when this happens. I ran it at idle in the driveway this weekend. A couple of minutes after I felt the t-stat open the engine dies and I was unable to get it started again. Any suggestions?
I have read several threads about the timing - which I have yet to check - and I think the timing may need adjusted, but should it advance to the point that it will not run? or even start? should the dura-spark controller retart timing 10degree for start up?
never found the power valve
but I got the truck running last night. I fiddled with the ECM wires. Found several splices which are questionable. I plan to re-work some of the engine electrical over the next week. I do not want the electrical to be questionable. I have a wiring diagram in my Hayes repair manual.
Next step
I found a Painless wiring harness for the ECM. $132 from Advance Auto. I will try to clean up the wiring myself.
I found more of the problem(s). I got the truck started and watched it idle as it warmed up. The choke never open up. I remember, now, the previous owner had the choke wired open, guess I found out why.
The choke is not moving at all. It must not be set up correctly, or may not be working at all. Also, the choke pulldown is not working. I think the pulldown will open the choke as vacuum is applied. Two problems here. The pulldown rod is not connected to the choke mechanism all the time. There is a connecting rod which falls out of the hole in the pull down rod. 2nd, the pull down rod does not seem to move as the the engine is throttled. If I understand correctly, more throttle means more vaccum which should mean the choke is pulled off by the choke pulldown. Please let me know if I am understanding this wrong.
So.... I will at least have to replace/ fix the choke and the pulldown accuator. I need to rebuilt the carb. or... I could just wire open the choke like the last guy.
Yes, you can purchase individual parts. I know the choke (I have a climatic choke) actuator housing as well as pulloff are available at NAPA. I don't know what type of choke you have so I can only relate my experience. A rebuild could expose/remedy any other issues which may not be corrected by replacing the other items.
climatic
I have the climatic choke. Good to know I can replace as needed, or as I have time to work on it. I have not verified the idle solinoid is working correctly. I found another problem. It seems that the choke mechanism is getting stuck with the choke fully closed. I can open the choke by hand, but it feels like it is catching on something. Need to work through the choke setup proceedure in my Hayes manual. Thanks for the comments above.
I have a 351M that will hold oil presure at 60 lbs for 20 or so minintes then dropes to 0 and starts to over heat,it has blown several head gasgets.I thought it was not getting oil up top so I though it was the camberrings, so I changed them and put a high presure oil pump and water pump and radior and it still does it.I would aperacate some help, if someone could, thank you
chiefsfootball
16
03-28-2017 01:40 PM
donerico
02-24-2017 12:17 PM
andrewscofield
04-18-2016 11:43 AM
katzklaw
17
12-24-2015 02:31 PM
twinzilla
02-07-2010 09:40 PM
