Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2003 Ford Escape airbag light
Old 04-23-2006, 04:25 PM
Chris.Levi's Avatar
Chris.Levi
Chris.Levi is offline
For a little while, it sounds like the problem is my five year old.
Old 04-23-2006, 08:23 PM
howaboutthisone's Avatar
howaboutthisone
howaboutthisone is offline
I love my Escape, but for as much as it cost, the fact that you cannot let anything slip under the passenger seat without losing the airbag function is a bit rediculous. I hope that others here will have more technical advice for you, but the advice that I can offer is nothing under the seat. That is pretty tricky when it comes to kids :-) I guess we can be happy that disconnecting and reseating the connector offers a temporary fix. At least our airbags will function. Ford really should offer to fix this. It is definately a major safety concern. I did report the problem to a data collecting site that I had found online. It implied that if an automobile manufacturer receives enough similar reports, that they put pressure on the car manufacturer. I'm not sure if I could find the site again, but I could try.
Old 06-19-2010, 12:52 PM
lyles's Avatar
lyles
lyles is offline
escape airbag light
I have a 2002 Escape with the same airbag light problem. This forum just saved me a ton of money. The dealer wanted to charge me $95 just to diagnose the problem. I found the yellow wire under the passenger seat and disconnected it, cleaned both ends with an electrical spray cleaner and reconnected. And guess what. The airbag light is off! Thanks!!
Old 06-28-2010, 12:11 PM
martin_csr's Avatar
martin_csr
martin_csr is offline
I believe there's a replacement airbag electrical connector that can be installed as well.
When doing airbag stuff, it's a good idea to disconnect the neg cable on the battery.
I've heard of one or two folks who have inadvertently deployed the airbag.
Norma stitz
10-16-2016 10:30 AM
aircargoo
1997-2006 Expedition & Navigator
08-13-2016 09:17 AM
xc4jokestomper
11-14-2012 08:11 AM
Mcroz
08-04-2012 09:00 PM
fordtrucksforever
1978 - 1996 Big Bronco
30
03-14-2006 07:26 PM
Quick Reply: 2003 Ford Escape airbag light
