I'm sure there's plenty of guys on this website looking for the same thing. Smoke=Power and high fuel flow.... It's the oooh ahhh factor really, nice to have, people wouldn't mod their trucks if they didn't want the performance.
As I understand it, our trucks smoke when there is too much fuel. So maybe big injectors will make a cloud for you. Mine doesn't smoke at full throttle (with no load), but towing a trailer it can. When pulling a trailer: more boost=more fuel and therefore more black smoke. Am I right in all this?
That sounds pretty correct to me, I was thinking about a low horsepower chip, as to try and not destroy anything in the transmission or torqueconverter, hoping that maybe that will give me just a little.
If you want smoke without a big load, you'll need to use a tuner on it's highest setting. I only get smoke w/o load if I load the 100hp setting on the Edge tuner.
I have an edge platinum that allows you to adjust for smoke in all settings if memory serves...I saw it scrolling thru the menus...there was actually a sliding scale (incremental) with more smoke being at one end of the scale ...don't remeber what was at the front end. I'll check tomorrow and get back.
Dump a quart of oil down your exhuast you will throw oil at the car next to you, and when it gets hot enough it will smoke. it will smoke... that is if you can handle the mess. hahahh. Or just put the ebrake on then you will have a load and no back brakes when you need them!
no just kidding. i wouldnt do either unles you would wanna. but me and a buddy put oil in his exhaust and it smoked alot when the pipe got really hot. but it was a big mess.
i would do what the other guys are saying. get a chip and turn up way up to a high setting. then you will have more power and the smoke you want!
Mitch
if its smoking alot its just overfueled. dirty air filter will get you plenty of smoke. i run a decent sized injector and the turbo i run it only smokes if i lug it.
