headlights, foglights not working
the other night, the headlights, (lowbeams) stopped working, the high beams only work on the "temp" setting and not when you push the turn signal lever forward. I also found that the fog lights don't work. I checked fuses, bulbs and the switch and all is well. The autoparts store told me that there is no relay for the headlamps. Any idea what to check next??
The only good thing is I have to leave work a bit early now!
Hi and welcome to the forum
Power goes from fuse 8 in the fuse box under the hood to the headlight switch. Did you check that one too?
From the headlight switch power goes to the multifunction (dimmer switch) on the red/yellow wire.
I would start by checking for power at the headlight switch dark blue/orange wire. That comes from the fuse under the hood.
If you have power there then check for power coming out of the headlight switch on the red/yellow wire.
