Creaking noise
Check all of your cab supports, tranny mount, engine mounts, and look at your leaf springs. If there are no little plastic pads between the ends you will need to fix that. Take a large screwdriver, pry the ends of the leaves apart far enough to stick a piece of plastic that is as wide as the spring and 3" long doubled over (so it looks like a C). The easiest plastic to use is the old oil containers from your last oil change. This solved a funny pop/squeek I had.
MoreBoostPlease
07-14-2011 04:10 AM
builtfromiron
05-28-2011 08:27 PM
