78 longblock question
Old 02-23-2006, 11:10 AM
telmoff's Avatar
telmoff
telmoff is offline
Question 78 longblock question
I am replacing the engine in my sons 1970 F100. I know that the engine is a 78 351w, do I need to know what it came out of before ordering the longblock? The dipstick is in the front right side of the block. I will be replacing the intake and carb also so I'm not too concerned about the intake matching up.
Old 02-24-2006, 01:10 AM
TigerDan's Avatar
TigerDan
TigerDan is offline
If you want a new longblock that's close to what you have, just the info that it's a '78 should be sufficient. But you might want to consider getting an earlier one so you get the better heads, unless the rebuilders are particular about getting a core back that's exactly the same as what you bought. Might be able to upgrade for a little extra moola. '78 was not a great year in terms of heads. Low compression, smaller valves, low power...'70 through '77 were much better.
Old 02-24-2006, 01:22 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
1978 did not have a 351w stock. they only had 351m
Old 02-24-2006, 05:13 AM
telmoff's Avatar
telmoff
telmoff is offline
Thanks Tigerdan, I am not returning the old long block. I will take your advice about an earlier year.
Old 02-24-2006, 10:14 PM
ford390gashog
you better make sure you infact have a 351w.
Old 02-25-2006, 06:22 AM
telmoff's Avatar
telmoff
telmoff is offline
I'm sure it's a 351w my wrench tracked it down and the guy I bought it from confirmed when I got the truck he had changed the engine.
Old 02-26-2006, 12:35 AM
ford390gashog
instead of taking someones word , i would count the valve cover bolts. the number of bolts is unique to all the series of engines. see if you have 8 bolts.
mountain dewd
20
12-08-2016 09:34 AM
farmpaw
20
03-20-2016 06:41 PM
dave91gt
Modular V8 (4.6L, 5.4L)
02-26-2014 01:34 PM
stein78
10-27-2006 10:59 PM
Hellbore
05-20-2006 03:31 PM
Quick Reply: 78 longblock question
