98 exp 4.0 sohv misses at idle runs fine top end
hi all
i have a 98 ford exp 4 wd with the 4.0 sohv engine my problem is cel is on, had codes pulled at advance auto says bank 1 and 2 too lean and misfire in cylnder 2 . engine runs great at highway speeds but at a red light or sitting in the bank drive thru it idles like its got a dead plug . i have replaced the plug wires with ford dealer parts as i replaced the spark plugs from dealer also, that didnt help. exp has 136000 miles on it does not use oil . ive been reading a lot of post on here and it seems like that the upper and lower intake manifold gaskets might need to be replaced? does this sound like it might be my problem also? if so how hard a job is it .compared to changing the dreaded headgaskets on a 94 ford thunderbird as i just did that on my wifes t-bird last month did that with no problems. any insight would be greatly appreciated .
thanks in advance
911bear
thanks in advance
911bear
update ford part # YL2Z-9E473-AA ????s
i went to the ford dealer today and told them what my explorer was doing and he told me it sounded like a blown intake gasket , he said they had done 3 this week , we,ll i told him to give me the parts i needed and he handed me a small box ford part # YL2Z-9E473-AA TOLD ME IT WAS AN updated kit it came with 6 blue rubber o-ring type gaskets 2 black rubber gaskets a new left side timing chain tensioner a small brass plug and a plastic stick , it seems to me that there should be more to it than that it would appear that it should have a "vally pan" type gasket also any feedback on this kit would be greatly appreciated . thanks very much for all the help so far!
911bear
911bear
Seems to me that you have more than you need to fix the manifold gaskets!
BTW, I concur; it sounds like a vac leak on the manifolds and it's a common problem but fairly straightforward to fix.
All you need to use is the six o-ring gaskets and whicever of the others is the upper manifold gasket.
The timing chain tensioner you can do if you think it's apporpriate, certainly it's worthwhile if you have the manifolds off but not strictly necessary unless you have noise issues from the existing tensioner. It won't make a bit of difference to the lean condition; that's a classic 4.0 manifold gasket issue.
dexterslab724
2004 - 2008 F150
08-12-2017 12:51 PM
TexFord
1997-2006 Expedition & Navigator
11-30-2002 08:51 PM
