borg warner transfer case
There are two BW models that for used, the BW 1345 and the BW 1356. I think the 1345 was phased out around 1984ish??? Someone please correct me if I'm wrong.
Both the models use the same mounting systems, both to the crossmember and to the tranny output.
There may be differences in spline counts for output shafts of the transmissions, maybe someone else has more knowledge on the specifics, but that's my best shot.
Good luck!
Good luck!
Received 3,108 Likes
on
Originally Posted by witdog2020
You never said what year zf, I'm guessing a 1356 would bolt up, The 1345 was much shorter and different drop angle.
on
on
as Long a the ZF was from a 4X4, you should not have any problems.check the trans to t-case shaft connector for proper splines. also, before you go to all the bother putting it together, check that the lower trans mount bosses on the adapter are not broken, and that the t-case shifter mount holes are not stripped. i have seen a few of them broken due to the steel bolts seizing to the aluminum housing, and when you try to take them apart the boss snaps. the adapter housing is $200 from ford.
