97 F150 Tire Swap Speedometer Issues
Mine has 235/70/16 tires.
Had a 3:55 with a 21 tooth.
Went to a 3:08 with an 18 tooth.
I am sure if you doodle a bit you might be able to figure your out.
I am thinking I had a 15% change in ratios so if you figure yours there you go.
Or use the 3mph per tooth.
Smaller driven gear increases the spedo reading, larger slows it.
BrushPopper
02-05-2016 03:12 AM
Mr7.50headsup
02-20-2014 11:22 PM
kedwinh
57
07-28-2013 08:26 AM
