Rear end slipping?
Maybe the rear brakes are sticking on one side or both...since that is what it feels like, that is what I would check first. Check the motor and transmission mounts. Check the differential for slop in the ring and pinion. Check the pinion bearing. Check the universal joints. I can keep going but those are the items I would go for first...
when I first got my 97 I had the same problem I took it back to the dealer (it was used but had warranty) They added friction modifier fluid to the rear end and the problem stopped. They did however tell me that this was a maintenance item and charged me 80 bucks. The truck had about 20000 miles at the time and now is over 55,000 with no further problem.
mcne
22
10-30-2017 05:13 PM
ToolDude
12-07-2005 09:55 PM
