56 Ford F-600
Received 1,353 Likes
on
on
F250-600 use larger wheel openings and are interchangable. F100 is unique. Cab, inner fenders, hood, nose, etc are all interchangable. Big truck cabs usually have several extra holes in the dash for various controls, tach, etc.
Larger truck doors are made to accept the wider mirrors as used on dumps, they will still be fine on a F100 and a regular mirror used.
The cabs are the same. I took a '55 f100 cab and put it on my '56 f600. I have never heard of the doors being bigger. The metal may be thicker to support the heavy mirrors, but overall dimensions, I believe are the same. Fenders are interchangeable, f600 fenders would look very odd on a f100. I run 9.00x22.5 tires on front. Little 16 or 17 inchers would look lost in the big fender opening.
on
I used the doors and grill from a 56 F600 on my panel truck. Around here, the F600's were used as grain trucks on farms. They are usually in much better shape than the pickups as the floor is higher off the ground and most of it's use was in the spring and the fall. The rest of the time the big trucks sat in the barns and weren't driven much in the winter.
Years ago, I parted out a 53 Chebby 2 ton truck. Found out that the brand X trucks had different grill, hoods, and inner fenders.
rustyrelic
10-18-2015 02:46 PM
Bucsfan552
03-19-2012 08:19 PM
Nawlins56_F600
02-25-2004 02:26 PM
