Transfer Case Fluid
Old 02-03-2006, 04:28 PM
Rich in CO's Avatar
Rich in CO
Rich in CO is offline
Transfer Case Fluid
My owner guide states I should use Mercon ATF in the transfer case, can I use the same Mobil 1 synthetic ATF that's in my tranny? or should I just stick with the dino mercon.
Rich
Old 02-03-2006, 04:39 PM
PSNut's Avatar
PSNut
PSNut is offline
Rich
Go with the cheaper one.
Old 02-03-2006, 04:41 PM
Fat Diesel's Avatar
Fat Diesel
Fat Diesel is offline
Go with the expensive one. LOL. It's only two quarts. I've used both Mobil 1 and Red Line when I've done mine.
Old 02-03-2006, 04:58 PM
wlihntr's Avatar
wlihntr
wlihntr is offline
ditto...i use the syn in both my trans and x-fer case
Old 02-03-2006, 05:03 PM
Kwikkordead's Avatar
Kwikkordead
Kwikkordead is offline
Another vote for the synthetic. While the drain plug is out, look very carefully inside for any little bits of plastic. If you see any at all make immediate plans to get that transfer case rebuilt.
Read this thread for an explanation:
https://www.ford-trucks.com/forums/s...d.php?t=393461
Old 02-03-2006, 05:17 PM
PSNut's Avatar
PSNut
PSNut is offline
Any particular reason for having to go with the syn for a transfer case?
Old 02-03-2006, 05:22 PM
Rich in CO's Avatar
Rich in CO
Thanks for the help
Rich
Old 02-03-2006, 05:32 PM
PSNut's Avatar
PSNut
PSNut is offline
Didn't see any proof that syn would have helped prevent those transfer case failures.
Old 02-03-2006, 05:33 PM
wlihntr's Avatar
wlihntr
wlihntr is offline
after i had 20,000 miles on my truck i checked the X-fer case fluid and was badly burnt. the truck had been in 4 wheel drive 4 or 5 time for total of about 20 miles. i dont know what caused it but since i switched its been fine. the truck has 61,000 on it now
Old 02-03-2006, 05:38 PM
PSNut's Avatar
PSNut
PSNut is offline
Well that's interesting! Ford spec's a fluid that won't stand the test of time and usage which could lead to failure at their expense to repair.Hmmmmm...WTF.
Old 02-03-2006, 05:42 PM
Kwikkordead
Never tried to offer any.
I'm simply saying while the drain plug is out, check for the telltale signs of shift fork failure.
Old 02-03-2006, 05:46 PM
PSNut's Avatar
PSNut
PSNut is offline
Well u gave a vote FOR the syn and tied that to a thread on transfer case failure so i took that as supporting data on your vote.
Old 02-03-2006, 05:52 PM
guzzle92's Avatar
guzzle92
guzzle92 is offline
I'm getting ready to change mine out. I'm going with Redline D4 ATF. Less than $10/qt delivered to my door.
Old 02-03-2006, 06:23 PM
Fat Diesel's Avatar
Fat Diesel
No proof here other than an early T-Case (search the Kwik archives for his findings) has 180,000 on her and I've changed out the fluid twice, both to Syn.
Beatings include, but are not limited to, high speed 4-low runs in the sand at Pismo, high torque low speed rock crawling on granite in the sierras, stump pulling, bush yanking, etc. Oh yeah, she's been airborne at least 4 times. Will this suffice in the absence of proof ?? LOL.
Old 02-03-2006, 06:31 PM
PSNut's Avatar
PSNut
PSNut is offline
Was those beatings done during the pre-syn era?
Quick Reply: Transfer Case Fluid
