Dale Dually
Dale Dually
I have a 2001 dually F-350 super duty 4x4. This truck is equiped with manual lockouts. When ever the lockouts are engaged, the front diff makes a knocking or thumping sound when turning to the right or left. It usually starts at about 2/3rd's turning radius. This is with the transfer case in the 2wd position. If I unlock the hubs the sound goes away. I've had it looked at by the dealership and they say it's fine. Any ideas?
Dale,
This is a normal occurrance when you turn tightly in either direction with the hubs locked because now the axle shafts are connected to the wheels and so the ujoints at the nuckles are turning along with the axle shafts and they bind up slightly when you turn sharply in either direction. Just to be safe you can grab the ujoints and see if there is any excess play in them.
Also welcome to FTE great people and info around here.
BTW when start a new post for a title pick a description that describes your problem and this will draw people with the answer to your thread quicker.
76supercab2
General Automotive Discussion
09-10-2005 10:58 PM
