66 f100 heater core
66 f100 heater core
Hi there -
Do any of you sly dogs know where the heater core on
a 66 f100 is located? I'm guessing it's somewhere behind
the glove box. I can see bolts on the firewall, so I'm thinking
the easy way to get at it is to take the padded panel on top
of the dash off... Please advise, if you know about this
perplexing conondrum!
- Paul in Seattle
- Paul in Seattle
If it is like my 65, the heater core is inside the black heater box (Plenium), (the one the fan is in) below the dash on the passsengers side. You have to remove the nuts that hold the box to the firewall (which are in the engine compartment)... the bolts go through the wall. Once the nuts are removed the box kinda falls out. Remove the hoses, which also go through the wall. You unplug the blower motor wires- and if you have any vent adjuster cables remove them. Also remove the screws that hold the defrost tubes to the box (they will be brittle and tear easily.) Once the whole heaterbox is removed there are several clips that hold the box together. Remove the clips, Split the box apart and VIOLA' one heater core. I just did this in a '60 falcon yesterday - a '65 last year, and a '62 2 years ago. All of the procedures where basically the same. Unless they where change drastically from '65 to 66.. that should work. It took me 2 hours to remove the heater core and replace the new one, from start to finish. It takes a second person to hold the heater box in place until you get at least 2 nuts threaded. I hope this helps.
you need part number 399024 www.kragen.com . also the same heater core was not used. 61-65 94572 66-72 399024 and 73-79 398016/39923 all have different heater cores.
Paul Therriault
02-25-2018 07:00 PM
dadgonebroke
05-10-2015 07:51 PM
