4x4 front end and factory underdash a/c found it pick-n-pull junk yard if anyone wants it
Hi pinion 1/2 ton 69 or 70 near complete drum to drum + TC and most steering, springs... I think the cost was <$150
The A/C is for a <72 and goes under dash, missing compressor but has Ford logo and controls.
Anyone interested?
Anyone interested?
I am very interested,(in the A/C that is ) but if the lines were left open it probably has some corrosion in there ,but if they were shut off to the outside air it is probably in good shape , if so let me know , please,
Benny
Benny
I did notice the lines were open and the compressor was missing. Part of the label was missing too. It's the type that goes across the dash at the bottom and the exchange bolts under the center.
I actually didn't pull it, I just saw it and noticed that it looked usable. I think they charge about $75 + core.
They'll be having a 1/2 off sale in 1.5 weeks but I bet it's gone by then, I rarely see these things.
Where are you located?
Karljay, I am in Paris Texas,
I would be willing to bet that the damp air has rendered the evaporator useless, If it was left open for any length of time so I will pass on this one but thanks anyway,
Benford
Benford
I would be interested the A/C unit. Did it go the whole lenght of the dash to passenger side? I really only need the houseing part w/vents in the truck that goes under the dash. Mine has been kicked a few times and is cracked and broke off at the last vent. I'm in Reno,NV Don't know if you want to hassel with shipping.
Yvonne
Yvonne
Actually it's not all that far from you. I spotted it at the Rancho Pick-n-Pull off Sunrise about 3 miles from Hiway 50. It is the one that goes under the dash and looked to have two vents in the center and other at the edges.
I haven't pulled it because I don't really have much need for it. It's probably about 2 hour drive for you if you want to check it out. Let me know if you want more details.
By the way, I heard that everything is 1/2 off this weekend so you could grab it for cheap.
It's the Rancho pick-n-pull on Sunrise. The truck looks like a 70 longbed F100 styleside. As you walk in it's on the right side probably 3~5 rows back and about middle of the pack. It'll be facing away from you as you walk towards it.
the vent stuff is off and sitting there and the main unit has brackets connecting it to the underside.
Veeb0rg
08-11-2003 02:37 PM
