66 Econoline Fuel Tank
Old 01-03-2006, 08:20 AM
surfmon's Avatar
surfmon
surfmon is offline
I'm in the process of restoring my first Econoline(66') and am having trouble locating a fuel tank.
Any help would be appreciated.
thanks
Travis
Old 01-03-2006, 02:49 PM
jschira's Avatar
jschira
jschira is offline
The fuel tank for a 61-67 Econoline is not reproduced, so you will have to recondition your tank or buy a used one. They show up on ebay from time to time.
Old 01-03-2006, 06:24 PM
Texas Cop Car's Avatar
Texas Cop Car
Texas Cop Car is offline
Fuel tank
Didn't I read here that a car tank will work if you relocate the filler neck?
Old 01-03-2006, 09:26 PM
Jimbare's Avatar
Jimbare
Jimbare is offline
all alone in the world
where are you located travis? i know econoline owners, all over the country and might be able to hook you up with a tank that way! let me know!
jim
Old 01-04-2006, 05:56 AM
jschira's Avatar
jschira
jschira is offline
No. The 60-65 Falcon tank filler pipe in on the top at the back. The Econoline is on the driver side bottom. The Falcon tank drops in from above and has a lip to keep it from falling through the hole in the trunk. The Econoline tank mounts from the bottom.
I guess you could rig something up, but I don't think that it will be pretty.
The Ranchero/wagon tank might work, but they are not reproduced either and are as hard to find used as the Econoline tank.
Old 01-04-2006, 10:29 AM
surfmon's Avatar
surfmon
surfmon is offline
thanks for the info so far everyone................email being sent
Old 01-08-2006, 10:44 PM
j-md's Avatar
j-md
j-md is offline
One on e-bay right now and closes shortly ... $ 99.00
Old 07-14-2015, 03:43 PM
Frog151's Avatar
Frog151
Frog151 is offline
Fuel Tank
Im in the process of installing a fuel tank in my 63 econoline van.
I purchased a 1975-1977 FORD E-100 E-150 E-250 E-350 ECONOLINE FUEL GAS TANK F15A from Impala Bob's inc. It has the same dimensions as my original, but with a deeper tank.
My only concern is the fill tube, it sets forward of the original by about 4 inches.
I'll add an update after tomorrow. I'm taking it to Dig's Rod Shop.
The rod shop site has pictures of what they have done to the van.
Old 07-15-2015, 12:04 PM
j-md's Avatar
j-md
j-md is offline
Econoline Tank
You'll likely have to re-do the fuel intake ... I have a Mustang tank in my 66 that was redone by Fred Carello in R.I. ... just had to buy longer straps and it doesn't hang down on the rear end. The vent and filler tubes were re-used from the original tank and were relocated ... lots more gallons and still good after 10 years ... only minor issue that I never tried to figure out is that the new sending unit pegged the original fuel gauge beyond full but once the old fuel gauge gas quantity was reached, it behaved normally. Just got used to watching it go down and was not interested when it was full.
Old 07-15-2015, 12:20 PM
j-md's Avatar
j-md
j-md is offline
If you are looking for front discs D & D sells a complete bolt on dual master set up ... nice job on that body work
Old 08-21-2015, 03:28 PM
icehouse330's Avatar
icehouse330
icehouse330 is offline
Gas Tank Renu Services - Looper Servicenter - Refurbish Automotive Gas Tanks
I have a 61 econoline pickup and have the same problem.
I was going to use these guys...anyone have any experience?
Supercab
45
12-27-2020 12:13 PM
Falcon123
01-07-2017 10:47 AM
littlejohn64
03-22-2016 09:27 AM
runawayhound
09-24-2015 10:44 AM
robertrhyde
28
03-11-2011 01:26 PM
Quick Reply: 66 Econoline Fuel Tank
