I went to Strauss the other day to get some plugs for my tune up, and they gave me six plugs with the numbers AGSF22FM. My repair manual lists my replacement plugs as AWSF32PP. I have a 2000 3.0L V6. Are these the correct plugs? If so, why are the part numbers different?
According to the 2000 Ranger owner's manual that I downloaded, only the FFV 3.0L was available in 2000. So, the AGSF22FM is the correct plug. As Rockledge has stated the FM is for "fine wire", the latest platinum plug from Motorcraft. The AWSF32PP plug is called out for the 2.5L 4 cylinder.
FFV stands for "Flex Fuel Vehicle", and can run E85 fuel.
