Stuck wastegate on a 6.0 Garrett turbo
Who was it that said that the 6.0 does not have a wastegate?
Mine has stuck several times and I had to replace it today at a cost of $399.00 just for the part.
It is mounted on the side of the Garrett turbo and dumps exhaust gases to regulate the turbo boost.
Since exhaust gasses pass through it, it sometimes gets plugged with carbon according to the dealer. I got tired of trying to clean it, so I replaced it today.
When it fails, the turbo won't build boost and the truck will fall flat on its face..
Result: No power. It will run at idle fine, but when you try to tromp it, nothing.
Forddieselman..
All replies welcome.
And howdy to ya'all
Forddieselman..
And howdy to ya'all
...Welcome to Ford Truck Enthusiasts!
If you get a minute check out the link here, it will help you to navigate around and understand this site.
https://www.ford-trucks.com/forums/s...d.php?t=300691
We are happy you have chosen the best source for Fords!
Enjoy FTE and The State Chapters are located at the bottom of the main forum page.
JOIN CLUB FTE -SUPPORT THE FORUMS!
See you on the boards. ….
Moved and member notified
Is there anyway you could post a part#. I'm no expert on these engines, but I know for fact that they do not have a wastegate. The VGT vanes control the amount of exhaust backpressure inside the turbo by opening or closing. So I'm curious as to what part you had replaced/problems with. It could be someone is using the wrong term for a part. The price and problems you gave sounds like you had the EGR valve replaced.
Originally Posted by Forddeiselman
It has what is called ERTV. Something with electronically controlled turbo vanes. It also had the wastegate valve on it like I mentioned in my post. If you look at the turbo from the passenger side, it is right in the middle of the turbo between the exhaust and the intake wheels.
Forddieselman.
Forddieselman.
You are certainly describing the VGT actuator. If you've had to have yours replaced several times, perhaps you've got another problem... probably stuck or sticking vanes in the turbo. It doesn't function as a wastegate, what it does is open and close vanes in the turbo to change the size of the turbine housing to give you the best all around performance.
Ford 6.0 turbo
Check out this website: www.powerstroke.com It has a gread clip explaining hoe the Garrett VGT turbo works!
