Stuck wastegate on a 6.0 Garrett turbo
Old 01-15-2011, 03:08 PM
Zmann's Avatar
Zmann
Zmann is offline
your so punny
Old 01-15-2011, 03:10 PM
amdriven2liv's Avatar
amdriven2liv
amdriven2liv is offline
I'm hitting easy street
Originally Posted by Zmann
your so punny
I just had to say something! I don't know how many times I've jumped on a thread and then deleted all I had written cause odds are the person in 2004 doesn't even have the truck any more. It took me a while to read the dates first.
Old 01-15-2011, 04:01 PM
Zmann's Avatar
Zmann
Zmann is offline
I hear ya .
Old 09-11-2012, 07:40 PM
willwitt2005 f-350's Avatar
willwitt2005 f-350
willwitt2005 f-350 is offline
help me
Originally Posted by Forddeiselman
Who was it that said that the 6.0 does not have a wastegate?
Mine has stuck several times and I had to replace it today at a cost of $399.00 just for the part.
It is mounted on the side of the Garrett turbo and dumps exhaust gases to regulate the turbo boost.
Since exhaust gasses pass through it, it sometimes gets plugged with carbon according to the dealer. I got tired of trying to clean it, so I replaced it today.
When it fails, the turbo won't build boost and the truck will fall flat on its face..
Result: No power. It will run at idle fine, but when you try to tromp it, nothing.
Forddieselman..
All replies welcome.
And howdy to ya'all
I havew just brought a used 2005 6.0 nice 108,000. already put 12,000.00 on it
cahanged oil twice alreay also all fuel filters truck running great until this morning after runnning 6 hours refueled and about an hour later stsrted get sluggest no black smoke .. put fuel additive in thinking it wasb bad fuel no luck
got worst no black smoke just no pwer took exhaust off not gettinh a good flow also chcked the air filter still no change I think it's the turbo control the turbo is winding up and building some presure but this truck used to screem! what might be the problem my 7.3 has 455,550. on it I've done al my own work on it but this a little different help me please will
Old 09-11-2012, 08:29 PM
BLADE35's Avatar
BLADE35
BLADE35 is online now
You Need some gauges
I use ScanGaugeII
Go get it scaned for DTC auto zone and other do for free
but the SGII will probably find the Issue and it could be a few diff things
Old 09-11-2012, 10:39 PM
Mich6.0's Avatar
Mich6.0
Mich6.0 is offline
In the parts diagram it calls the VGT SELENOID a WASTE GATE $253 @ TOUSLEYS. IF your truck sites for a while they unisom ring while freeeze up and cuase that problem. My truck doesn't get used that often and thats what happened to me and also when you take it apart the actuation arm should only move 90-180 deg not spin all the way around, their is a 1/16 inch shear pin that could break like mine
xbox73
05-05-2014 06:47 PM
Knuts
03-01-2013 07:26 AM
radjcw5
09-20-2011 12:21 PM
eman588G
09-07-2011 07:56 PM
Quick Reply: Stuck wastegate on a 6.0 Garrett turbo
