how much horsepower a 351m/400 block can handle
Old 12-26-2005, 07:48 PM
old75F-100's Avatar
old75F-100
old75F-100 is offline
i was thinking if i turbo this engine what would be the hp limit before the stock rods break and the block cracks and wut about the crank if i was going to do this work i would do a rebuild with Arp bolts and copper head gaskets
Old 12-26-2005, 07:54 PM
MBBFord's Avatar
MBBFord
MBBFord is offline
With a stock engine just turbo charged, something would go wrong. If you did a complete rebuild and turboed it, it should hold up fine.
Old 12-26-2005, 09:24 PM
Bill_Beyer's Avatar
Bill_Beyer
Bill_Beyer is offline
Assuming a good rebuild with quality parts including forged pistons and a reasonable boost pressure you should be able to easily run up to 500 HP as long as you put some sort of rev limiter in it to keep under 6000 RPM. I would definitely make sure to keep the static C.R. around 7.5:1 to avoid detonation issues. 351M/400 heads aren't known for their great resistance to pinging/detonation.
Old 12-27-2005, 03:41 AM
Matts72's Avatar
Matts72
Matts72 is offline
I think ShaZam had around 700 horses with his... I think thats his username.
Mine makes around 385... no problems with it.
Old 12-27-2005, 03:46 AM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
i think 650 is about the limit. just have the block checked ofr cracks and make sure to have the engine balanced.
Old 12-27-2005, 10:14 AM
Bill_Beyer's Avatar
Bill_Beyer
ShaZam did some other mods to his pulling 400 like putting filler in the block that you probably wouldn't want to do with a street engine.
Old 12-27-2005, 08:47 PM
battered_bronco's Avatar
battered_bronco
battered_bronco is offline
i think it was 799/863 and about 16,000usd
and streetable if the lights are what 1/4 mile away and a long cooldown wait bween lights sounds fun but not real effective
but anyway isn't the wall thinnest at the bottom and furthur could you fill an inch or two up providing you can keep it 'level'
baddad457
18
07-27-2021 06:17 PM
Rudiak
1999 to 2016 Super Duty
06-27-2014 03:25 PM
blueeyedfordguy
General Diesel Discussion
12-16-2013 02:22 PM
17witha664x4
02-29-2012 04:04 PM
Joe mollnow
34
03-15-2005 11:01 PM
Quick Reply: how much horsepower a 351m/400 block can handle
