How to plug D3VE head egr ports?
Old 12-26-2005, 11:49 AM
madcitymike's Avatar
madcitymike
madcitymike is offline
Both the front and rears of these heads have an EGR hole that's approx 5/8". The fronts are already plugged by the factory, but I want to remove the plumbing for the egr and plug the holes. The fronts look like they're plugged with freeze plugs, so I tried 5/8" freeze plugs, but they're too loose. Can anyone suggest what I can use to do this?
Also, the motor I'm installing is missing one of the transmission alignment dowels. Is this a dealer only item, or will any parts store carry this?
Mike
Old 12-26-2005, 12:06 PM
thunderguns71's Avatar
thunderguns71
thunderguns71 is offline
I may be way off here, but Ill try. I beleive you find an appropriate sized metal rod and insert though the head to block off all the passages. Someone else with a answer will chime in shortly Im sure.
Old 12-26-2005, 12:28 PM
loveoldtrux's Avatar
loveoldtrux
loveoldtrux is offline
Hi MadCityMike - I had mine plugged by a local machine shop - I left 'em in the morning and picked 'em up the next day - looks like you'll need to go there anyway to get that dowel fixed anyway..... I'd take all 3 parts there and have it done professionally and forget about it.
Old 12-26-2005, 12:34 PM
madcitymike
I forgot I have a junk 460 block sitting out in the junkpile and just took a look at it and was able to use vice grips to get the dowels out of that one, so that problem is solved. I also found a post stating to tap the hole with 1/4" npt and then just use a pipe plug, so I'm heading out to the hardware store right now. Thanks!
Mike
Old 12-28-2005, 01:22 AM
Superdave's Avatar
Superdave
Superdave is offline
You don't have to tap anything.
You can go to your local NAPA and tell them you want thermactor port, cap plugs for your 460 heads. They tap right in like a freeze plug. They are an oddball size. You will see the same plugs in the front of the heads in the same spot.
And while you are at it get 4 and put new ones in the front of the heads as well. They rust out and will leak exhaust.
Matter of fact this the part number from a box of them I bought a couple years ago.
Clevite # 219-2188.
My NAPA store did not have them on the shelf and had to order them, so I had to buy a box of 8 or so plugs. They should be able to cross something with this number.
Old 12-29-2005, 10:45 PM
kermmydog's Avatar
kermmydog
kermmydog is offline
The factory uses freeze plugs, measure and go to the parts house and get a small freeze plug. been working for me.
Old 12-29-2005, 10:55 PM
Superdave's Avatar
Superdave
The cap plug I refer too is a small freeze plug and the part number I gave is for the OEM replacement cap plug and exact proper size for the thermactor holes.
Old 08-29-2015, 04:46 AM
fun4evrusa's Avatar
fun4evrusa
fun4evrusa is offline
I am getting ready to do this same exact thing. Removed all of the smog crap and need to plug the holes. Looks like I am going to NAPA tomorrow. I will give status.
Old 08-29-2015, 06:28 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
4) 380393-S .. Cup Plug (plug thermactor holes in head) 43/64" O.D.
Pic: Listed below 6049 cylinder head.
Old 08-29-2015, 06:10 PM
fun4evrusa's Avatar
fun4evrusa
Engine Head EGR Hole Plugs
Thanks for the info. Went to NAPA and THEY HAD THEM!!! $0.99 ea. god I love NAPA.
So, I have read several threads on how to do this. Some say clean out the carbon and fill with hi-temp RTV, some say to fill the holes with steel rod, etc., etc. What is the best method? The two rear facing holes are completely filled with carbon. The front right has one of these caps already installed from the factory, which I am going to replace. The front left also has one installed, but has a hole corroded through it. Basically going to put new plugs in all fours holes, just need to know the best preps before I do this.
Thanks in advance!!
John
Old 08-03-2016, 05:29 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
anyone know the napa part number i need to go get some of these
Old 08-04-2016, 06:43 PM
thrifty's Avatar
thrifty
thrifty is offline
I went to Napa today and got my plugs. Thanks for the info. Skip they gave you a clevite # the guy at napa can cross reference the number for you.
Old 08-04-2016, 06:59 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
ya i got the clevite nu,ber, i ordered a 1/4 npt tap and some plugs too incase i wanna go that route
Spaznaut
07-11-2017 09:22 PM
fishfreak101
02-10-2017 04:27 PM
1995F250351
07-19-2016 02:40 AM
mad_science
Modular V10 (6.8l)
07-05-2016 01:02 AM
scrobbie
02-22-2016 03:26 PM
Quick Reply: How to plug D3VE head egr ports?
