Worn OUT 4.6L needing help
I have a 1999 F-150 Flareside
4.6L Windsor 250,000 miles Engine is drinking the 20-50w oil, 3qts/tank of gas.
Seeking a lesser used motor for the truck. My wife says sell the truck but the truck is paid for and after my last wreck the whole truck looks brand new again. Still starts daily Had the truck since Jan 2001 @ 32,000 miles. Only other problem I have had (3) rearends replaced under warranty and after warranty ran out rebuilt (2) other times. Rearend is due for another overhaul(grinds & vibrates around corners) & Vibrates at speeds over 60mph.
Nope, Not racing it I Primarily use the truck as a daily driver & on the weekends I use it as a work truck for doing Landscaping, Hauling a 24' flatbead car trailer and a mustang atop, or Pulling a loaded 12' enclosed trailer for the BoyScouts.
I shelled out my first rearend at 39,000 miles pulling my car trailer with a 1965 chevy pu on it. I ended up having to load the ford on the trailer and pulled it home with the 65 chevy. After the Third time the Dealer would no longer work on that rearend said I was over using my truck. Said I should have bought the F-250 super duty to do what I do. Which didn't make sense to me because my Dodge Dakota 1998 did the same stuff No problem just had weaker springs.
Have you looked at salvaged? I see a few complete 4.6L engines with low miles for $1900.00 including shipping to my zip (Bay Area). Try the link below:
http://www.urgpartsearch.com/link/search.cfm
4k for a Ford 4.6 rebuild or 20k+ for a new truck. My money is with the rebuild.
4k is for the engine alone. install is extra @ 95.00 a hour X 13 plus other parts.
a truck with 250k is worn out further than just the engine, you will need a new tranny soon enough and a list of ther things.
