Aerostar Ford Aerostar
Does a Water Pump push or pull through a Heater Core
Old 12-21-2005, 09:01 AM
Baggins's Avatar
Baggins
Baggins is offline
Let me explain that more clearly (read in the vein that I am still not getting the heat that I should)
This is more of a curiousity question to help me solve an ongoing problem.
A) Does a Water Pump "Pull" the colder coolant out of the Heater Core, thereby drawing in the heated coolant behind it at the same time.
or
B) Does the Pump "push" the heated coolant in, forcing the colder coolant out.
I'm leaning towards (A) in my theory (the return hose is not getting as hot as it should making me think that the inlet to the pump is partially blocked, because I've flushed out the Core with a garden hose, did it last night when it was 6°)
Heat will get "hot" at high engine rpm but not at normal operating rpm's, (only gets fairly warm)
thanks
Dan
Old 12-21-2005, 06:09 PM
96_4wdr's Avatar
96_4wdr
96_4wdr is offline
the heater core is plumbed into the water pump suction side, and to the water outlet area before the thermostat...so flow is from hot just before thermostat thru heater core to intake side of water pump...coolant is pulled by water pump and pushed out into block and heads...
probably cause of low heat output from heater
1. failed stuck open thermostat...radiator return tank should get too hot to keep hand on...indicated by your comments that engine runs cool
2. air dam in core> purge per Aero forum previous posts or see Ford service cd
3. mineral deposit plugging of heater core...common in areas with high mineral content in water...not removeable by reverse flushing...can be seen in radiator tank crossflow tube ends
does your engine overheat easily?>look for water pump impeller damage-failure
Old 12-21-2005, 06:33 PM
lasher's Avatar
lasher
lasher is offline
where the coolant comes out of the engine there is a thermostat that is closed when the engine is cold and at this point and forces water to go to the heater core. so the coolant is pushed into the heater core and the return goes back into the pump in take.
so you either have a bad thermostat stuck open or a blockage
Old 12-22-2005, 08:15 AM
Baggins's Avatar
Baggins
Baggins is offline
Well "maybe" I finally found it.
On a '93 going into the "suction" side (top) of the water pump, the heater core return hose flairs dramatically to go over the inlet stem.
The interior of that hose just above the flair had seperated and was collapsing under suction, which was reducing the flow substantially.
This was kind of my theory behind my question. Since I had flow through the block and the Heater core and high engine rpms was producing more heat, I was figuring something was blocking the water pump inlet,(draw side) but wasn't sure what (stop leak, sediment, foreign object etc.)
It's still not as hot as I remember it being, but it's better, I just need to replace that hose now.
thanks for input
Dan
Old 12-22-2005, 10:33 AM
copper_90680's Avatar
copper_90680
copper_90680 is offline
If I remember correctly, the high pressure side is on top of the engine, near the thermostat and the low pressure side is near the water pump. The high pressure side should go to the bottom of the heater core for proper purging of the air from the heater core. Otherwise, air will be trapped inside the heater core, giving you less heat than it should.
Old 12-22-2005, 11:13 AM
Bear River's Avatar
Bear River
Bear River is offline
Former ******
I'm glad you found the problem. I never use local water in my engine, I either use premixed or mix my own with distilled or RO water, so that mineral deposits do not form.
Old 12-22-2005, 11:21 AM
Greywolf's Avatar
Greywolf
Greywolf is offline
The hoses in a closed system should be under constant pressure any time the coolant has reached operating temperature and expanded - a collapsed hose shouldn't be possible unless you have leaks or a failed radiator cap.
Old 12-22-2005, 11:31 AM
Bear River's Avatar
Bear River
Former ******
Well, a hose collapseing is very possible, because the system may be under constant pressure, but there is still a pressure differential before and after the pump. If the hose is seperateing, the inner layer may collapse, but the hose itself does not collapse as a whole.
Old 12-22-2005, 11:35 AM
Baggins's Avatar
Baggins
Baggins is offline
That is correct.
I think what is important to keep in mind is the location of failing inner wall of the hose and the fact that it wasn't collapsing it was being sucked into the inlet, causing a 'restriction" of flow not an elimination of flow.
Or at least that is my current theory
Dan
Old 12-22-2005, 12:40 PM
96_4wdr's Avatar
96_4wdr
96_4wdr is offline
collapsing suction hoses are the main reason the water pump intake house from the radiator usually has an interior coil to keep it open in proper hose designs. lower hose on Aero...
interior heater hose breakdown goes unnoticed in heater hoses because most owners don't examine them for softness or imperfections along length.
Old 12-22-2005, 02:12 PM
copper_90680
96_4wdr:
The strange thing is that most replacement lower radiator hoses do NOT come with that spring. I had to reuse the old spring inside every time I replace that lower hose. I do that every couple of years regardless of how the hose looks. Just a precaution against being stuck on the side of the road on a vacation trip.
Come to think of it, I would probably qualify as a hypochondriac
granny_rocket
01-20-2015 06:48 AM
poorF250owner
1999 to 2016 Super Duty
10-28-2014 11:23 AM
73 ford guy
78
10-14-2013 12:17 AM
silan
Aerostar
13
12-04-2006 04:40 AM
borland
03-22-2001 02:31 PM
Quick Reply: Does a Water Pump push or pull through a Heater Core
