steering ratios
steering ratios
Thanks for the info. The reason I asked was because I'm thinking that aside from the power steering being easier to turn at low speeds it might also be nicer in a straight line because small corrections don't require as much movement of the steering wheel. What do you think?
steering ratios
Sedric,
Strangely enough a better ride on the highway is achieved by the larger ratio. Over corrections cause side to side weight transfer that have led to oversteer problems under highway speeds. Because Ford builds such a loose steering system, its really not an issue. The power steering is 100% better than the other system. I own both and my favorite is determined by the power steering.
Good luck, Have Fun,
KingFisher
KingFisher
eriksf250
01-07-2012 07:15 PM
Bart99GT
12-10-2004 09:40 AM
