Modular V10 (6.8l)
No oil pressure!
Old 12-01-2005, 05:59 PM
50BMG's Avatar
50BMG
50BMG is offline
No oil pressure!
About a week ago I lost oil pressure in a 2001 F-250 V-10 4x4. I immediately pulled over and checked the oil which was fine. When I restarted the truck the gauge was back to normal, so I replaced the sending unit.
Thought that was the problem but now its doing the same thing again.
The oil pressure gauge will jump up and down then go down to zero and the light will come on and then it will sometimes jump back to normal or stay like that until I shut it off and start it again.
Dont know what to do but I definitely dont want to drive it like this.
Could it possibly be a bad connection to the sending unit?
Anybody else experience anything like this before?
thanks,
jeff
Old 12-01-2005, 06:37 PM
captchas's Avatar
captchas
captchas is offline
Guest
sound like a sludged up oil pump pick up. which means pulling the pan and replaceing the pick up.
i've done many since the advent of jiff/car wash oil change services putting in the wrong oils and pee poor grade oil filters in on oil changes..
Old 12-01-2005, 06:47 PM
FortyFords's Avatar
FortyFords
FortyFords is offline
Get a mechanical guage and do a test first.
As charlie has said we've seen it all here.
Rich
Old 12-01-2005, 09:24 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Does it knock or tick when it does this?
If not, it's probably a sender/gauge problem.
Do what Rich said, and hookup a mechanical gauge before going crazy like Cappy wants you to
The oil sender/gauge is a glorified (and not so much glory there) idiot light. The gauge goes up to half-way when the oil pressure is above, what, 5-7 pounds? It doesn't move up and down with varying pressure, it's just an idiot light.
Old 12-02-2005, 01:05 AM
50BMG's Avatar
50BMG
50BMG is offline
No knocking or ticking at all and the gauge read zero for maybe a half mile once when I couldnt pull over because of traffic.
The engine would be making a lot of noise with low or no oil pressure wouldnt it, would there also be a rise in engine temperature?
Saturday I will check it with a manual gauge and see whats going on.
Thanks for the help guys.
Old 12-02-2005, 08:39 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Sounds like the gauge is flakey... or the connections going to it.
I wouldn't think the engine temp would spike enough to see it right away. If it was spiking, you'd already hear lots of banging
But, don't drive it this way until you verify that the pressure is really there with a mechanical gauge.
Maybe you should just install one under the dash in the middle just for peace of mind for the "long haul" ???
Old 12-02-2005, 08:43 AM
captchas's Avatar
captchas
captchas is offline
Guest
i have to back up art.
DO NOT DRIVE TILL you know whats going on. having worked in a dealership for 41 years oil pressure can cost big bucks if not cared for . even if it turns out to be a bad gauge.not driving is only a safty factor.
Old 12-15-2005, 12:44 PM
bbock's Avatar
bbock
bbock is offline
I have a 2001 V-10 excursion with 58000 k--2nd yr I had it I first noticed that in cold weather 20f or so and below the oil pressure gauge freezes and red oil can light appears--no noise etc--still runs fine--brought to dealer--of course it works fine when I leave it there. Had it in for radiator flush 2 days ago and it did it again--now every morning it sticks--after 2 -3 min or after I rev engine slightly the gauge reacts and the light goes off--mechanic at dealer told me that its probably the sending unit--Im wondering if it could be the oil viscosity maybe also-- may get too thick till warmed and thinned.
Bill in NY
Old 12-15-2005, 12:49 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Nah, I doubt it's viscosity related - if anything, with thick oil in the cold, the pressure is WAY high until it warms up a little bit. My '74 highboy's 390 w/high volume pump would hit 80 pounds at idle when cold with 10w40, within 2-3 minutes it was down to 55 (at the same RPM).
Old 12-15-2005, 12:57 PM
bbock's Avatar
bbock
bbock is offline
must be sending unit then
Its scary--just lost an 88 Grand Marquis same way almost--engine lt came on -- oil/wtr ok--drove a few miles--dead
Is sending unit hard to install? expensive?
Old 12-15-2005, 01:25 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Probably $10 aftermarket. Pretty easy - not sure if it's a copper washer type seal or you need teflon tape - make sure before you put the new one on.
Old 12-15-2005, 01:28 PM
bbock's Avatar
bbock
bbock is offline
oh really--great thanks for the info--its probably near the oil filter somewhere right?
Old 12-15-2005, 01:35 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
I think it might be up near the front of the block on the same side as the oil filter, but not sure, and I don't have my service manual CD here right now.
Anyone?
Old 12-15-2005, 01:38 PM
bbock's Avatar
bbock
bbock is offline
If u ever happen to look at it soon Id appreciate if u could drop me a line abt where it is--im not too much of a motorhead --17 yr old son is though--just got a 68 chevelle malibu-- loves the muscle stuff hahaha
Benningtonr
12-21-2015 11:41 AM
n4ynu1010
17
08-04-2012 09:05 AM
Mr-Pipeline
Modular V10 (6.8l)
30
05-17-2010 10:13 PM
jthiel
1997-2006 Expedition & Navigator
07-20-2007 09:53 AM
CharlesNeff
07-17-2007 06:51 AM
Quick Reply: No oil pressure!
