74 4x4 speedo cable is irratic and jumping around.
i think i need to lub up the speedo cable on my 74 4x4,it started to fluctuate really bad today.i havent driven the truck in a couple weeks,and today it started jumpin around. anyone know how to lub the cable,and what kind of lub to use? any help would be great.-billy
There is a clip where the cable enters the speedometer behind the dash. You can reach it without puling the instrument cluster if you have small hands. Press the clip in while pulling back on the cable housing and it will release. You and then pull the cable out of the housing. Wipe it clean, then use Lubripate white grease to grease it (a thin coat all over). Slide the cable back in the housing, slide the housing back onto the speedometer (retaining clip will engage automatically), and you have a quiet, steady speedometer.
My speedo wouldn't even register until I got up to about 20 mph and then it would be very unsteady. Saturday I pulled the entire cable assembly from the inst cluster to the trans out and dissambled everything. Mine is a two-piece with a sensor with two wires on it(I think it's for the cruise control). Cleaned everything and lubed with Hillco Lube. Works like brand new now!
rvpuller
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
53
02-27-2016 01:02 AM
PRUSue
12-11-2011 12:06 PM
