New Hampshire Chapter Join Chapter Leader: 7283-F250
starter problem
Old 11-27-2005, 06:26 PM
glawto's Avatar
glawto
glawto is offline
Talking starter problem
starter just turns over with out the ignition wire and starter wire hooked up only the batteries wire are hooked up from the battery to the solenoid from the solenoid to the starter and the neg battery cable is grounded i moved the ground from the bell housing to the engine block bolt holding the engine to the engine mount.
Old 11-27-2005, 07:37 PM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
jruggles
04-20-2014 12:42 PM
Rich1953ard
04-28-2013 10:34 AM
mike2112
04-11-2010 09:26 AM
jln_Wasabi
Electrical Systems/Wiring
03-03-2004 10:36 PM
55forder
11-02-2002 10:48 AM
Quick Reply: starter problem
