Resetting odometer on a rod
My 1950 cab is now on it's new frame and almost ready for the paint shop!!! All of the electrical and mechanical stuff is done, and now it's time for some dry-fit reassembly.
One thing I would like to do is set the odometer to 000000. I am using a cluster from an '84 Ranger and it is driving me nuts trying to figure it out.
This is a frame-off, frame doesn't match motor doesn't match cab franken-rod, so Johnny law can't have anything to say about the numbers when it's registered. Already checked with DMV and they ok'd it for me.
Any advice would be appreciated.
/Kris
/Kris
Years ago I worked for a Caddy dealership. The odometers were a replaceable item, we even kept them in stock for late 50's thru early 80's Caddys. We would dissasemble the cluster and remove the old odometer, adjust the new odometer to match teh mileage and reassemble it and send it down the road.
The odometers had little tabs that protuded between each number wheel and a plastic tab that held them in line until you placed it in the cluster. To set the mileage you would remover the tab and start spinning at the lower end (the right) when the ones place was correct you would hold it tight to the tens place and rotate until that # was correct, then hold the ones and the tens and rotate to get the hundreds and ...so on and so forth until you had the mileage you needed. Then drop the odometer back in the cluster and make sure the gears meshed.
I'm not sure how the old ford gauges are but its got to be similar.
Good luck with it
Bobby
Good luck with it
Bobby
There is a row of star gears below the numbers wheel that "probably" holds everything in place as you describe. It is pressed in, so I think I am going to visit Mr. vice in the garage and see what we can do together.
Worst case scenario I have to get another one from the wreckers.
Thanks all,
/Kris
Thanks all,
/Kris
Bobby,
I know what you mean. I think inflation has set in and I think a pic is worth more than a 1000 words these days.
BTW, this is my speedo-does anyone know how the needle attaches in that hole down there? I have the needle, but haven't taken it apart any farther than to reset the numbers. This was my "learning curve" as I figured I couldn't screw it up anymore than it already was.
Kris-sorry if I'm hi-jacking your thread!
johnny1720
02-12-2002 10:34 PM
Johnny Mo
1997-2006 Expedition & Navigator
02-06-2002 11:29 AM
