77.5 front axle on an early 77??
Old 11-07-2005, 10:55 AM
77f2504by4's Avatar
77f2504by4
77f2504by4 is offline
i have a high pinion d44 lying around that came off of a 77.5 f250. will it bolt up to my early 77 with no mods?
Old 11-07-2005, 12:05 PM
KubotaOrange76's Avatar
KubotaOrange76
KubotaOrange76 is offline
Its Comin Right for us!
Received 1,441 Likes on 937 Posts
yes it will...onlything is the early 77 should be low pinion...so you could have to shorten the driveshaft a bit....and the yokes may be different, i have seen them both with 1310's and 1330's
Old 11-07-2005, 02:36 PM
leadmic's Avatar
leadmic
leadmic is offline
If you are going to use the devorced T-case and your truck is not lifted you might have a problem with front drive line rear trans. crossmenber interfearence.
Leadmic
Schickel
10-06-2013 02:17 PM
460
02-02-2010 11:36 AM
torquemeister
25
12-17-2008 02:38 PM
Raptor
Offroad & 4x4
05-25-2006 05:22 PM
lifted77f250
03-30-2006 08:18 AM
Quick Reply: 77.5 front axle on an early 77??
