pulls strong untill about 3000 rpms then misses and spits 1989 inlinesix
Old 12-02-2008, 08:54 PM
DJdemon6696's Avatar
DJdemon6696
DJdemon6696 is offline
got new sparkplugs new fuel flter new wires new coild/rotor.. ran some injector cleaner thru it.. pulls REALLY strong untill 3000 im not shure i dont have a tach then it begins to miss and spits and no more power.. i know the inline six is not a high revving motor but it doesnt suppose to die like that does it?
Old 12-03-2008, 12:14 AM
Opossum's Avatar
Opossum
Opossum is offline
Is this at full throttle only or does it hit this wall in neutral also?
Old 12-03-2008, 05:20 AM
DJdemon6696
full throttle in any gear but not in neutral
Old 12-03-2008, 05:41 AM
Opossum's Avatar
Opossum
Opossum is offline
Replaced the air and fuel filter latety? How bout tune up is that in good shape?
It must seem like I'm not giving any answers but I don't have much to work with either, it's running out of fuel or spark either will cause what you describe. If it's been a while sence you have done these tune up items do them for good measure anyway. If you have tried these things, try shortening the gap on the spark plugs and see if it gets better.
Edit, sorry just reread your post if this started right after the tune up then definitely try shortening the plug gap.
Old 12-03-2008, 06:07 AM
red bud's Avatar
red bud
red bud is offline
Can't tell if you meant to say cap/ rotor or coil/rotor? I was going through this last week and it ended up being the coil.
brobrad
06-27-2013 11:47 AM
$100special
07-11-2010 08:33 PM
FL_BWAB
03-21-2007 04:32 PM
fitzz47
06-02-2006 10:41 AM
Quick Reply: pulls strong untill about 3000 rpms then misses and spits 1989 inlinesix
