Aerostar Ford Aerostar
Shift indicator does not match actual gear.
Old 11-06-2005, 12:16 PM
Agent Iron's Avatar
Agent Iron
Agent Iron is offline
When I purchased my my 97 aerostar the gear indicator said reverse when you were in park. Now the indicator says 2 when you are in park. I still have all my gears, but things don't match up. I tightened the torx bolts that hold the bracket which connects the shift cable under the column, but they were plenty tight. I lubricated the cable as it has always been stiff to shift, but this made no difference. What other variables are there? What else can be moved in order to allow the column indicator and transmission to match? I can't find any adjustment at the trans. I tried to loosen the large 19mm nut that mounts on the shift lever at the trans, but it does not want to move, and was half afraid if it actually did. I don't know how that would make any difference anyhow.
Help
Thanks
Jay
dan_s_johnson
1997-2006 Expedition & Navigator
07-13-2011 10:42 AM
starrider
09-06-2010 09:15 AM
jgedwards
1997 - 2003 F150
02-17-2010 02:39 PM
Forest
04-26-2006 08:29 AM
Quick Reply: Shift indicator does not match actual gear.
