Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
MIG Welding Stainless
Old 11-04-2005, 09:03 PM
f150_514ci's Avatar
f150_514ci
f150_514ci is offline
Do anybody know if Lowe's or Home Depot sells stainless MIG wire? And if so what type should I get? I have a Miller 210 mig welder and it mentions 3 different types of wire that you can use. I'm only looking to get a 2lb. roll.
Old 11-05-2005, 06:37 AM
bob arrington's Avatar
bob arrington
bob arrington is offline
get .035 thousanths and use pure argon for your shielding gas . if you havent run a mig that often , get some mild steel scraps , copper wire and practice.you dont want to ruin a stainless piece due to slopy welding, bob
Old 11-05-2005, 03:01 PM
f150_514ci's Avatar
f150_514ci
not really what i was asking
Old 11-05-2005, 04:28 PM
cficare's Avatar
cficare
cficare is offline
How would you put a 2# roll of wire on a Miller 210? Are you using a spool-gun?
Old 11-06-2005, 10:30 AM
SSCX2's Avatar
SSCX2
SSCX2 is offline
Just read the lable most mig wire will weld stainless steel.
As far as stainless steel mig wire never heard of it.
Old 11-06-2005, 12:11 PM
f150_514ci's Avatar
f150_514ci
i can use a 2lb or a 10lb roll in mine just have to change a few things
Old 11-06-2005, 11:46 PM
Schmids4.9l's Avatar
Schmids4.9l
Schmids4.9l is offline
I dont think lowes or home depot sell spools. TSC might though. I live about 25 minutes from Hobart Inst., and about 20 from a big welding supplier called Weiler Welding, finding welding equipment is easy
Old 11-07-2005, 08:08 PM
andy79's Avatar
andy79
andy79 is offline
Go to a welding supply store. They will have the wire. Also use a tri-mix gas. I believe it is carbon dioxide, argon, and helium.
Old 11-08-2005, 05:08 AM
bob arrington
why the tr- mix? and my suggestions were based on the inexperianced " sounding" questions that you were asking,bob
Old 11-08-2005, 04:31 PM
farmtwuck's Avatar
farmtwuck
farmtwuck is offline
For MIG welding SS you need the following:
Tri-mix gas, (andy79), then the appropriate gauge wire (.035,.045, whatever) for your machine. Seems like Bob is confused on the wire: regular MIG wire isn't copper but it has that reddish coating on it that makes it look like copper.
You need to consider what alloy of SS you have and get the appropriate wire. The different alloys can have very different welding characteristics.
SSCX2: you may be able to weld SS with regular MIG wire but the weld will rust. Kind of defeats the purpose of SS.
I've never seen the wire at Lowe's or Home Depot. You might luck out at Sears. Best bet is welding supply store.
Hope this helps.
Old 11-08-2005, 05:15 PM
bob arrington
Hope this helps.
not confused , just suggesting a way to cheaply practice prior to buggering up a good piece of stainless ,which , since Im a self taught welder , makes sense. respectfully,bob
Old 11-09-2005, 12:13 AM
guthrie&co's Avatar
guthrie&co
guthrie&co is offline
.35 and .45 wire! dang what are you guys building? bridges and battleships?! i used to work for ppi motorsports and buil;ding chassis we used .25
Old 11-09-2005, 01:17 AM
f150_514ci's Avatar
f150_514ci
Hope this helps.
finally someone with an answer ,lol thanks for the info
Old 11-09-2005, 10:12 AM
farmtwuck's Avatar
farmtwuck
Bob, I definately agree with practising on scrap before you tackle the real job. I was only talking about the MIG wire. It isn't actually copper wire, just looks like it. But, you probably already knew that.
Old 11-09-2005, 01:56 PM
Schmids4.9l
Im pretty sure its copper coated, well I think it is anyways. Before I have to weld something that needs to look nice, I always do some practice beads, get the heat and wire speed set just right. Actually, if I need something to look good, I'll TIG it if possible.
Quick Reply: MIG Welding Stainless
